FE Technical Forum
Look at this filter adaptor
Topic: Look at this filter adaptor (Read 3316 times)
BigBlueIron
Sr. Member
February 06, 2019, 05:05:50 PM »
Filter adapter sourced from ebay, as I was cleaning it up some I noticed this crack. Seems like Ive seen this before but not this pronounced. What say the committee?
Re: Look at this filter adaptor
Reply #1 on:
February 06, 2019, 05:13:13 PM »
You sure that's a "crack" and not just a seam found in cheaper pipe? ERW (Electric Resistance Welded) pipe - like cheap black iron water pipe.
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
BigBlueIron
Sr. Member
Reply #2 on:
February 06, 2019, 05:26:06 PM »
Yes I'm sure it is the seam weld.
Reply #3 on:
February 06, 2019, 11:54:21 PM »
Doesn't look like a crack to me, but like Kevin said. It'll be under compression on both ends, so I wouldn't see it causing a problem.
FE Technical Forum
