Author Topic: FE Power Cylinder Heads  (Read 210765 times)
Re: FE Power Cylinder Heads
« Reply #180 on: March 22, 2019, 11:13:37 PM »
When going to the conventional exhaust port location, the plug has to move.  I can still get it in the same area of the chamber, but it comes in at a different angle, more like a conventional FE head.
Hemi Joel
« Reply #181 on: March 25, 2019, 06:00:38 PM »
Amazingly good job on those heads, Professor Brown! Next, we need to tun you loose on some Hemi stuff.
« Reply #182 on: March 25, 2019, 06:03:03 PM »
SOHC owners are puckering Joel. ;D
jems68
« Reply #183 on: March 25, 2019, 06:17:35 PM »
After the heads get developed I want Mr Brown to produce a block with a raised cam tunnel. We can only go so big with the bore but we could stroke the heck out of it. I know it might not look like the way to go but I will take cubic inches anyway I can get them.
Hemi Joel
« Reply #184 on: March 25, 2019, 07:33:05 PM »
1" Raised cam, .500 raised deck, 4.8 bore spacing!
« Reply #185 on: March 25, 2019, 08:06:14 PM »
Funny you mention that, it is next on my list.  Maybe by this time next year...
« Reply #186 on: March 25, 2019, 08:28:56 PM »
Do you ever sleep?   :)
428 GALAXIE
« Reply #187 on: March 27, 2019, 06:46:15 AM »
Didn't Jay gave a little hint about the free time on these.
Full time FE POWER "employee"? :-X
Mikko
« Reply #188 on: April 02, 2019, 04:27:44 PM »
I was looking at a display of spark plugs at a trade show, some are tiny, like 10mm threads and use a 1/2" socket. Something like that could free ip a lot of space or make more positioning options in these heads. It isn't like they need to fit the spark plugs the old heads used.
« Reply #189 on: April 02, 2019, 09:16:50 PM »
My 10 mm spark plugs that I use in my aluminum heads use a 5/8" socket just like the regular 14 mm plugs.  Also, with the 10 mm, I found on the dyno that indexing them was useless for any power improvement since they are so small and placed optimally.  Not a bad idea to think about, but they are sometimes hard to find locally.  Joe-JDC
JERICOGTX
« Reply #190 on: April 03, 2019, 09:36:05 AM »
Very nice work Jay. The stock exhaust port option, is going to be a big seller.
« Reply #191 on: April 04, 2019, 11:34:43 PM »
Since everything from the crank to the valve covers will no longer fit the 4.8" why not go to 5.3" bore space and we can have 927's
Be kind of cool to have the FE become the "go to" ProMod engine.
Hemi Joel
« Reply #192 on: April 06, 2019, 02:59:09 PM »
I stopped over at Jays and saw the sand patterns. Amazing stuff. I am in awe that Jay has no formal or vocational training in this automotive design and casting field, yet here he is wazzing out top shelf stuff.
57 lima bean
« Reply #193 on: April 06, 2019, 05:07:06 PM »
                        This shows the sign to be true..."All Are Welcome"
« Reply #194 on: April 06, 2019, 10:18:18 PM »
LMAO!  Even former trunk monkeys...  ;D
