Author Topic: valve seals on heads question.  (Read 2954 times)
GJCAT427
« on: January 27, 2019, 09:03:35 AM »
The Tunnel port head I have had PC seals on both intake and exhausts. Question can you run umbrella seals on the exhausts and PCs on the intakes with out doing any harm? I keep reading that PCs on exhausts will possibly gall and to use the umbrella on the exhaust for more oil lube. Would this cause a smoker and use more oil than I want? Give me the pros and cons. Guides are cast iron by the way.
Re: valve seals on heads question.
« Reply #1 on: January 27, 2019, 09:20:15 AM »
I use Viton seals on every engine, both intake and exhaust.  Cast iron guides or bronze.
« Reply #2 on: January 27, 2019, 09:48:45 AM »
I also run viton on most stuff both sides.
Some race folk run no seal at all on the exhaust side, and I have done that a couple times when the engine showed a tendency to stick a valve (iron head stuff back in the proverbial day) with no apparent ill effects.
