Author Topic: Valve pockets in pistons  (Read 5222 times)
winr1
« on: January 26, 2019, 05:19:08 PM »
How deep are yalls valve pockets and at what lift, duration ??
Curious as I have not mocked my mill up yet to check for clearance
Ricky.
GJCAT427
Re: Valve pockets in pistons
« Reply #1 on: January 27, 2019, 08:55:36 AM »
Mine are TRWs popups from the muscle parts program L2299s They are modified on the domes about .060. The valve reliefs are about 3/16" as measured with a tape measure. The cam is a C8AX-6250-D with .600 lift and 330* duration as per spec sheet in the blueprint specs from Ford. This is a pretty rad cam in its day but what the he!!. I`m gonna try it. Hoping to start assy this week if the garage and the weather cooperate.
gt350hr
« Reply #2 on: January 28, 2019, 11:54:58 AM »
  What cam are you using?
winr1
« Reply #3 on: January 28, 2019, 02:52:58 PM »
Thanks GJCAT427
gt350hr, not sure till I mock the block up
428 crank in .040 390 block, late model SP pistons, shaving around .087 off the tops
Hankering to get it together to check ....  bench racing at the moment :-)
Ricky.
gt350hr
« Reply #4 on: January 29, 2019, 12:47:41 PM »
     Cutting the piston that much will also ( obviously) shallow the valve pocket by .087. Anything more than 230 @ .050 on a 108*lsa should be CAREFULLY checked. Hopefully the "deck thickness" of the piston is still more than .200 or it will likely cave in in the center.
winr1
« Reply #5 on: January 29, 2019, 04:00:39 PM »
Looks like the deck where the valve pocket is the deepest is around .465
The deepest part of the pocket is around .190, so deck is .275 thick at deepest part of pocket
Top ring land is around .316
This is as the piston is now, not milled .087
Will not be going over .220 @.50 or .500 lift .. 108
Where is the piston in the bore when the piston and valve are the closest ??
Ricky.
CaptCobrajet
« Reply #6 on: January 30, 2019, 09:01:10 AM »
Check the exhaust from 12° btdc to 6° btdc.  Check the intake from 6° atdc to 12° atdc.  Most any usable cam with 108 to 114 separation will get closest within those ranges.  I check in 2° increments unless they are really close.  Sometimes on aggressive cams you have to check every 1° through there.  For a 220 at .050 cam, the 2° increments are fine.  Be sure to zero your indictor on the retainer after each move of the crank, then push it down until it bumps the piston.  If you have the heavy springs on,  you can do it with the adjuster if you lube the threads and pushrod cup prior.
Blair Patrick
gt350hr
« Reply #7 on: January 30, 2019, 02:23:34 PM »
   Your cam should only have .119 lift "at the valve" at 10* ATDC. This should still be safe with a valve pocket depth of .100 or more. As Blair suggested check to be sure . The piston should have moved about .010-.014 off of TDC at the checking points he suggested. Piston motion is still "kind of" slow but is ready to speed up quickly around 20*S ATDC and why many of us aren't bothered by "total lift" numbers because the piston is often 1" away from the valve at that point.
   Randy
« Reply #8 on: January 30, 2019, 04:47:02 PM »
Never hurts to put clay or a cutaway head that allows you to see the valve fit. Sometimes the valve notch is not in the right spot.
winr1
« Reply #9 on: January 30, 2019, 05:40:52 PM »
Thanks much guys :-)
Ricky.
gt350hr
« Reply #10 on: January 31, 2019, 10:36:47 AM »
      Tom ,
         The cut away head is THE most valuable tool there is for piston to valve checking. Tough to do on an FE with the rocker shaft  but a bolt on plate can be fashioned to hold the shaft in place along with a  normal stand.  Crane Cams had a display of a small block Chevrolet that featured the front cylinder , a single cylinder crank , rod and piston and cutaway head. I was able to "play " with it for an hour or so waaaaay back in '75 and it has stuck with me all these years. I was able to borrow it 15 years ago to teach a class I had at a company I used to work for. It opened allot of eyes as to what actually happens between valve and piston. I was able to show the effect of lash change not being direct to piston to valve clearance that was a big surprise to most of my "students".
     Randy
