Author Topic: Edelbrock Head, Things To-Do Before Installing  (Read 10789 times)
FirstEliminator
« on: January 21, 2019, 01:03:43 AM »
   Hey guys,
    On the box it says something like "Ready to Bolt On". I have the feeling this isn't entirely true. Looking around you-tube searching for cylinder head work I've found several videos that talk about new cylinder heads needing a valve job out of the box due to guide to seat concentricity being pretty far out. It's been said the Edelbrocks at least need a good cleaning before installation.
   So, I have the box fresh heads. A Winona PH2000 seat and guide machine with cutters, arbors etc. Various Sunnen measuring tools. A couple years ago I was hot on the subject for quite a bit. Then it sat idle as I was into other things. Anyway, time to blow off the dust and make something happen. Is there any advice/recommendations to touch-up these Edelbrock heads without using the words "send them to someone else" ? Valve or seat angles, clean up here or there in the bowl and port or any info would be appreciated. The engine these are going on is a mildly peppy street engine.
   thanks,
      Mark
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
chilly460
Re: Edelbrock Head, Things To-Do Before Installing
« Reply #1 on: January 21, 2019, 10:04:28 AM »
My Ebrocks had a pretty sad valve job, the seat was not concentric to the guide, meaning the valves were slightly off center, and obviously wouldn't seal.  The constant side loading of the valve head as it hit the seat off center could have caused a valve to break at worst, increased guide wear at minimum.  The actual valve job was crude as well, been a long time but think we picked up 10-15cfm at lower lifts just with a professional valve job.  Take a look at valve to guide clearance as well, mine were on the tight side.
« Reply #2 on: January 21, 2019, 11:14:26 AM »
Why the h... is Edelbrock continuing to sell
heads with bad valvejobs and thight guides
seems like it have been known to man for years
that they have a lousy valvejob. Had no one
complained? total lack of QC?
« Reply #3 on: January 21, 2019, 01:10:46 PM »
If your using the small valve head edelbrock 2.09 intake , order bare and install 2.15 intake valve as they will match the seat way better than 2.09's , a tip from Blair Patrick for my local machine shop to perform when I upgraded my 1999 ebrocks heads to 11/32 intake stem , my local guy commented on how nice it matched up with the 2.15 intakes per Blair's advice
edit to add , check out  the oil returns and modify as needed , my heads valve cover rail bolt boss is extremely close to a couple Valve Spring so I clearenced my heads around the boss to give the oil a little more room to return away from the valve spring
« Last Edit: January 21, 2019, 01:15:29 PM by e philpott »
FB
« Reply #4 on: January 21, 2019, 01:28:52 PM »
if i was buying a set after what i learned from the last set, in addition to the above statements, i would put thread inserts into the intake threads and open up the drainback holes.
and check the locations of the intake holes too.......mass production has a little to be desired when there is a lack of QC.
to the statement of "hasn't anyone complained"? the answer is of course people have complained, but if their experience was anything like mine, edelbrock
cops an attitude and makes statements like "thats impossible" "because we are edelbrock sir"
edelbrock is no different than any other aftermarket manufacturer.....you have to trust nothing and check everything
Fred
« Reply #5 on: January 21, 2019, 03:26:50 PM »
In addition to the above, the production cutters only go about an inch inside the ports, and often leave a significant step where they transition to as-cast. a few minutes in each hole with a tootsie-roll will be well worth your while.
FirstEliminator
« Reply #6 on: January 21, 2019, 07:29:33 PM »
Awesome, thanks for the info so far. I will let you guys know what I find with this set.
Mark
68 Monterey 390 C-6
« Reply #7 on: January 21, 2019, 09:41:39 PM »
A new in box current Edelbrock head has addressed the drainback issue a long time ago - assuming you use an equally current intake gasket and manifold.  The valve job that comes on them is generally functional although simplistic.  The springs are similar - rather stiff (for a flat tappet) single springs with a damper, combined with a stamped steel spring locator and non-viton seals.  Having installed many of them on budget oriented builds and subsequently run them on dyno I can say that they are a decent usable alternative to old iron at a very fair price.  I can also say that they do leave plenty of opportunity for significant improvements at a fairly modest cost.
Pentroof
« Reply #8 on: January 24, 2019, 11:25:32 AM »
From a general cleanup perspective, I find the Edelbrocks have remaining sharp edges within the chambers...edge of the quench pad and around the spark plug hole. In general, not good practice for eliminating potential hot spots that could induce preignition. My last set even had one chamber on one head that missed the deburring op altogether. Usually, they just have an edge break, but this one was as-machined...just one chamber.
Jim
« Reply #9 on: January 25, 2019, 11:43:14 AM »
Key statement,  quoted for truth.  The thing you don't check is the one that bites you.
« Reply #10 on: January 25, 2019, 08:26:08 PM »
I don't particularly like the springs, and they tend to be pretty stout.
The last two sets I used, I swapped springs on one, the other was a favor to get a guy running at his house, we slapped them on and they ran great
As others said, they aren't fancy, but haven't seen junk either
FirstEliminator
« Reply #11 on: February 06, 2019, 08:07:54 AM »
So far, what I found with the heads is I don't have a 3/8 pilot for my seat and guide machine. It's ordered and will be here Friday. Then I can check concentricity.
    Progress so far is the 482 crank, rods and pistons are installed in a now clean block. Hoping to have it done and in the car for Beaver Springs.
Mark
68 Monterey 390 C-6
FirstEliminator
« Reply #12 on: February 15, 2019, 08:57:22 AM »
   With 3/8 valve stems I had ordered .375 and .376 pilots. Neither fit, they were both too big. I measured the E-head valve stem and it measures .371. I measured some stock valves and they were also .371 which caught me a little off guard. Then got the .374 and .373. I don't see a .372 listed, but the .373 works. I started taking measurements of the heads. When putting a strait edge across the tops of the stems most of the exhaust valve stems are lower than the intakes. Some by as much as .030".  Shouldn't all stem tips be the same height? I was planning to use nonadjustable rockers. Will a .030 difference in stem height require different push rod lengths?
  I measured for concentricity and got a valve seat height gauge to compare seats to deck surface.  Here are a couple pics of the heads with the measurements. I did not measure the guides yet.  I feel like I should get the concentricity numbers lower. Ford recommends .0015". I think that's going to be tough with the old S&G machine I'm using.  As suggested above I will be putting bigger intake valves in.  Hopefully the exhausts can get corrected by touching the seats only a little bit.
Mark
68 Monterey 390 C-6
« Reply #13 on: February 15, 2019, 09:45:28 AM »
I hate to sink a valve to get a tip right, how about a lash cap if you need to make up the difference after you swap intakes?
Regardless, a fresh valve job, new intakes, and a touch up here and there will likely change all your measurements anyway, but I just hate to cut material away
FirstEliminator
« Reply #14 on: February 15, 2019, 10:28:09 AM »
I like the idea of a lash cap!
    If I am cutting the seats a few thousandths to get the seat heights similar, I don't believe that is a big deal. The worst one was .009 above the lowest on the exhaust seats. Not sure if I should bother with the .004.  The 6's and 9's I will attempt to correct.
« Last Edit: February 15, 2019, 10:34:22 AM by FirstEliminator »
Mark
68 Monterey 390 C-6
