Author Topic: Dual 4 linkage, Clutch Fork Rod, CJ Dipstick Tube, Trans Levers, Spring Brackets  (Read 4776 times)
fastfords
I have new low/ med/ high/ riser kits content is front/rear rods with brass nuts brass ends bell crank  made to factory s p ecs also sell by the piece starting at $ 20.00 each if  needed kits start at $ 120.00  need info call 614 678 0751 thanks kenny
« Last Edit: January 20, 2019, 03:17:06 PM by jayb »
All parts are made in house. no china or India junk.
fastfords
63/64 427 galaxie clutch fork rod
« Reply #1 on: January 19, 2019, 07:20:03 PM »
 1963 /64 galaxie big clutch fork rod this is the rod used 406 427 11 inch clutch this is a must on your rebuild also have zbar and pedal to zbar rod will sell in kit form or by the piece  prices start $50.00 to $300.00 need info call 614 678 0751 thanks kenny
« Last Edit: January 20, 2019, 12:29:53 PM by fastfords »
fastfords
cobra jet dipstick tube
« Reply #2 on: January 20, 2019, 08:51:17 AM »
i have new cobra jet dipstick tube that are jig bent and has the crimping at the bottom to hold dipstick away from counter balance has  the oblong hole in mounting strap this will pass all concourse judging made in the USA with pride price at $27.00 each or 4 tube $100.00 plus shipping
« Last Edit: January 26, 2019, 09:09:40 PM by fastfords »
fastfords
1966/67 fairlane 4 speed trans levers
« Reply #3 on: January 20, 2019, 12:43:41 PM »
i have new set of fairlane 4 speed trans lever there bent and hole punch on progressive press with part# logo then sent out for case hardened then tested on shafts for proper fit made in the usa with pride this lever last on a drag car or ever day driver and will pass gold star judging priced $65.00 a set  need more info call 614 678 0751 thanks kenny
« Last Edit: January 26, 2019, 09:11:02 PM by fastfords »
fastfords
427 bell crank spring return bracket
« Reply #4 on: January 20, 2019, 01:03:54 PM »
i have a new bell crank spring return bracket this bracket bolts on top left bolt of bellhousing  this is the part that all missing do to rust or broken off this is lazer cut out then put in press and jig bent to ford specs made in the usa  priced $21.00 each need more info call 614 678 0751  thanks kenny
