Author Topic: rocker stand shims  (Read 6441 times)
centredautomag
rocker stand shims
« on: January 15, 2019, 09:40:55 AM »
I need to shim my rocker stand .240 is there some shim kit avaliable
 Thanks Marc.
Re: rocker stand shims
« Reply #1 on: January 15, 2019, 07:06:50 PM »
I made my own. I got some 1/4" steel flat stock and used a drill press, a die grinder, and a large stone to make sure it was flat and even. After I trued it, it came out to about .240", which is what I needed to shim my Harland Sharps with POP shafts, stands, spacers. If you are planning on running studs, I bought some custom length ARP's from one of the vendors on here. I had to neck down the oiling one, as it was a straight 3/8" stud. Here's my homemade junk:
centredautomag
« Reply #2 on: January 16, 2019, 12:55:49 PM »
Very nice job. Time to get the tools out and play. thanks Marc
MrRupp
« Reply #3 on: January 18, 2019, 05:38:59 PM »
I know this is a dumb question, but how do you know when you need to shim your rocker stands ?
Thanks Clint
« Reply #4 on: January 19, 2019, 07:12:36 AM »
Thanks Clint
When the rocker arm pattern on the valve stem isn't where you want it to be.
« Reply #5 on: January 19, 2019, 10:33:59 AM »
Hey Nightmist 66 just noticing the single spring. Is the conical spring stronger than a regular spring or is the cam very mild seat pressure wise.
« Last Edit: January 19, 2019, 10:36:17 AM by Stangman »
« Reply #6 on: January 19, 2019, 07:32:41 PM »
The springs are/were a beehive. Very similar to the conicals. They were 155/377open for a custom solid flat tappet that just bit the dust a short time ago. They were set up with different shims/locks for break-in. Had the lightweight shell lifters in it and custom .115" wall  5/16" chromemoly pushrods. Now moving on to a slightly larger solid roller and dual spring setup...
« Last Edit: January 19, 2019, 07:47:13 PM by Nightmist66 »
« Reply #7 on: January 20, 2019, 01:58:35 PM »
Ok thanks, so did the cam go on breakin or just over time.
« Reply #8 on: January 20, 2019, 05:11:32 PM »
Happened during break-in. Brand new scratch build. 50 mins. run time.  :(
« Reply #9 on: January 20, 2019, 05:16:15 PM »
If those were the valve springs that you used for break-in, that's why it wiped....
« Reply #10 on: January 20, 2019, 05:32:28 PM »
So, have you had experience with these springs and flat tappets for break-in? They were set up with less shim and +.050" locks to keep the pressure down. Is it due to rate on these springs?
« Reply #11 on: January 20, 2019, 05:53:12 PM »
Yes, I use them quite a bit, but I always put a single spring or low pressure dual spring on during breakin.  I aim for spring pressures at around 90-100 seat and under 300 open.  You were likely still pretty high on pressure.
A .050” valve lock change will only change the spring pressures by 15-18 lbs or so.
« Reply #12 on: January 20, 2019, 06:02:46 PM »
Seat pressure was around 100psi and I can't remember what the open was.....
« Reply #13 on: January 20, 2019, 06:10:49 PM »
You can multiply your cam lift times the spring rate and add it to the seat pressure to find out.
It would take a lot of change to drop 55 lbs off the seat though.
