Author Topic: oil relief valve  (Read 6951 times)
dmazz
oil relief valve
« on: October 12, 2012, 12:30:25 PM »
 Jay whats your opinion on the oil relief valve? Take it out or leave in.
Re: oil relief valve
« Reply #1 on: October 12, 2012, 03:09:01 PM »
If you've got it, I'd leave it in.  I don't think there's a good reason to take it out, although with modern oil pumps it is a little redundant.
manofmerc
« Reply #2 on: October 18, 2012, 06:42:13 AM »
I just went through my center oiler 427 this past summer .I have always used the pressure relief valve in the past .This time around i replaced the spring with one from doug at precision oil pumps .Like Jay says probably redundant but it doesnt hurt a thing as long as properly installed .Doug
dmazz
« Reply #3 on: October 18, 2012, 07:50:28 AM »
I ordered one from Doug last Friday. Thanks for your help.
« Reply #4 on: October 19, 2012, 06:52:24 AM »
I have a Spring from Doug and a brand new Ford spring still in it's org box.
They are not the same spring.
The Doug spring is a little thicker and does not quite fit on the shoulder of the spool valve, perfectly.
The Ford spring, well is perfect. lol
Without testing I can not say how much the Doug spring will vent at, but bigger springs normally vent at higher pressures.
dmazz
« Reply #5 on: October 19, 2012, 07:19:19 AM »
That figures, nothing I do is easy lol. So whats next? I don't have a ford spring my block did not have a valve or spring.
« Reply #6 on: October 19, 2012, 08:48:01 AM »
I think the Doug spring would be fine.
It would be like shimming the spring for say 5 psi extra, maybe 10.
Just putting up the info that I have found about this.
