Author Topic: True High Nine differential  (Read 5488 times)
Leny Mason
« on: December 28, 2018, 09:23:24 AM »
I am told I need to find a True High Nine differential for off road does any one know anything about them, the pinion is high on them is all I know we are looking for one. Leny Mason
shady
Re: True High Nine differential
« Reply #1 on: December 28, 2018, 10:12:24 AM »
never heard of them. what gives the 9" the strength, is the fact that the pinion is low.  In a 4wd, the front  axle pinion is high because it is set up to run backwards. A high pinion would give you more drive shaft clearance, but you wouldn't gain any more ground  clearance because of the housing. If you were to put a 4wd front diff. in the back, it's going to break at the drop of a hat. Just my thoughts on it.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
gt350hr
« Reply #2 on: December 28, 2018, 01:25:51 PM »
 Have you tried asking Currie?  IIRC they did "flippped" 9" stuff.
« Reply #3 on: December 28, 2018, 01:46:12 PM »
I remember some aftermarket differential company who used a 9" gearset, with the front of the pinion supported, but re-arranged it in such a way as to get away from the additional drag caused by the conventional lay-out. At least that was the claim. It's been some years ago.
jmlay
« Reply #4 on: December 28, 2018, 01:55:51 PM »
Raising the pinion would also hep reduce driveline angles. Truehi9 is one manufacture. Currie and others sell one as well.
http://truehi9.com/cases2.html
http://www.new9inch.com/curriechp.aspx
Mike
« Reply #5 on: December 28, 2018, 02:39:42 PM »
Not sure why anyone would consider going this route except for off-roading. The only reason for the High 9 is for increased driveshaft clearance for rock crawling. It reduces strength of the center section and raises the driveshaft so that tunnel clearance must be dealt with, which isn't really an issue on raised 4wd applications. It has its place, but certainly not in the car world.
FElony
« Reply #6 on: December 28, 2018, 04:28:16 PM »
I am told I need to find a True High Nine differential for off road...
Reading comprehension there, dougie?  ::)
« Reply #7 on: December 28, 2018, 07:08:33 PM »
I have a friend that bought a centersection to his dragracing car
that had 12 Gm stuff inside with higher, pinion suposed to reduce
drag....well no doubt it do it but how much? Im sceptic that he can
feel any gain in the class he is driving. There was a lot i had put the money
in on that car to reduce drag...and wheight
https://www.youtube.com/watch?v=LTRCOpiJAt0
« Last Edit: December 29, 2018, 03:36:14 AM by Heo »
« Reply #8 on: December 29, 2018, 09:52:49 PM »
I've also heard of the 9"/chevy conversion to get better gear angle and free up some rotational HP.  Super stocker kind of trick.
« Reply #9 on: December 29, 2018, 11:04:33 PM »
Yes i gues  super/prostock where you chasing 1/100ths but in a backyard build
for the lokal track...nahh. Empty the pockets and blow your nose had the same
effect on et
« Reply #10 on: December 30, 2018, 02:16:18 PM »
Agree.  I'm just not the type to worry about it.  Like I tell everyone....."I wouldn't have started with a 4600# car if I was worried about being the fastest".
