Author Topic: Carter 4070 Electric fuel Pump  (Read 2925 times)
Saltshaker
« on: December 20, 2018, 07:21:06 PM »
Is this pump enough to support a 500hp FE...it flows72galper hr.  I added this to back up a carter mech pump. I was running out of fuel on the track and could not get 5200 in 3rd. With the electric pump I get 5800 but thinking it should pull harder. Also,using a 8x2 air cleaner...
Jon
« Last Edit: December 20, 2018, 07:26:01 PM by Saltshaker »
Re: Carter 4070 Electric fuel Pump
« Reply #1 on: December 21, 2018, 09:02:15 AM »
My Carter will hit 7200 rpm in any gear but yet to try it in fourth with a 3.70 gear because I just don't want to go that fast in my skinny VW front tires , I do run 1/2 inch fuel line with stock tank and a drop sump to a Y-Block under the Hood and then 3/8ths to each carburetor bowl of the 2x4
« Reply #2 on: December 21, 2018, 05:05:27 PM »
I ran one on a 302 in my Ranger because they are quiet and durable. I don't think it's enough volume for a big block, at least not enough to solve your issue.
