Author Topic: Correct clutch fork 428  (Read 2993 times)
happystang
« on: December 20, 2018, 02:51:54 AM »
Hi everyone,
I have a C6OA-6394-D bellhousing to go behind a 428 in a '68 mustang, I purchased a clutch fork for it but noticed it uses the clip in style fulcrum as opposed to the wire style fulcrum that my C6OA-6394-D bellhousing uses. The fork I bought is an ACP unit that's supposedly correct for my application, however it doesn't have holes drilled for a wire retainer- it just has a riveted clip in style retainer. Does anyone have a recommendation on where to find either the correct clip in style fulcrum or wire style clutch fork? (which one is easier to source?)
http://www.mustangtek.com/Bellhousings/C6OA-6394-D.html
Thank you!
« Last Edit: December 20, 2018, 02:55:28 AM by happystang »
Re: Correct clutch fork 428
« Reply #1 on: December 21, 2018, 12:34:18 AM »
Iprefer the later style fulcrum & fork that use a flat spring that fits thru a square hole  in the fulcrum. Much less hassle to Re&re the fork. I have bought new late style fulcrums from Mustang venders, and a heavier duty version from  McLeod.
happystang
« Reply #2 on: December 21, 2018, 04:38:35 PM »
I prefer the later style fulcrum & fork that use a flat spring that fits thru a square hole  in the fulcrum. Much less hassle to Re&re the fork. I have bought new late style fulcrums from Mustang venders, and a heavier duty version from  McLeod.
I actually ordered an NOS fulcrum on eBay last night, courtesy of Tony Branda.
Thank you for the suggestion!
