Author Topic: aluminum water neck  (Read 3909 times)
olman
aluminum water neck
« on: November 29, 2018, 08:29:44 PM »
Does anyone know where I could find an aluminum water neck for my new Edelbrock RPM intake? My old one is too far gone to put on such a pretty intake. Any cast ones that would maybe match the intake or even a chromed one. I don't have a edelbrock catalog which I thought would have arrived with the intake. Goes on my 63 1/2 Gal 500XL.  Thanks
Re: aluminum water neck
« Reply #1 on: November 29, 2018, 08:40:45 PM »
Here's one I just bought a while back to go on my RPM intake. Pretty cheap, but it seemed like a nice part and I had no issues with it.
https://www.summitracing.com/parts/rnb-902-1024
Edit to add that it does have the bung in it, which I didn't need so I just put a pipe plug in it. I'm not a fan of the chrome jobs because the chrome is usually the first thing to go under the hose, which then leads to bad corrosion problems.
« Last Edit: November 29, 2018, 08:45:53 PM by cjshaker »
olman
« Reply #2 on: November 29, 2018, 08:45:23 PM »
Cool, but does the early cars have to have a  15 or 20 degree tilt for the expansion tank? Don't have my old one handy.
« Reply #3 on: November 29, 2018, 08:49:23 PM »
The only expansion tanks I'm aware of are one piece units that have the thermostat housing built into the neck on the tank. I assumed you got rid of the tank since you asked about a thermostat housing.
« Reply #4 on: November 29, 2018, 08:55:30 PM »
Are you talking about this tank?
olman
« Reply #6 on: November 29, 2018, 11:18:48 PM »
Ooops, sorry, I was thinking of my 460 in my truck that I am working on and got the two mixed up. Haven't worked on the Galaxie lately.
chris401
« Reply #7 on: November 29, 2018, 11:37:20 PM »
In the EBay ad it says it will fit a Cleveland also. Never heard that before, am I the last to pick up on it?
Questions & Answers Ask a Product Question
Q:
Will this fit my 1971 Ford 351 Cleveland 2V, I'm needing to change the direction to clear the HEI distributor I installed thanks
Asked by GREG on August 05, 2018
A:
Thank you for your question. Dorman 902-1024 water neck thermostat housing will fit the 351 Cleveland engine, this unit is a non-swivel unit. Canton Racing 80-057 is a swivel 90-degree water neck that can rotate to provide more clearance if needed.
Summit RacingSummit Racing Answer - August 23, 2018
Answer This Question
