Author Topic: Cam bearing usage on 427 marine block.  (Read 4012 times)
GJCAT427
« on: November 23, 2018, 03:55:12 PM »
The block I got last summer is a marine block not drilled side oiler core. Which cam bearings would be correct for it? Std 390 hydro or 427 side oilers. When I got it the block had been tanked and oiled. Getting ready for assy and running a factory solid lifter cam. Barry, Brent or Blair?
Re: Cam bearing usage on 427 marine block.
« Reply #1 on: November 23, 2018, 05:32:47 PM »
Are the cam bearing bores in the block grooved?
CaptCobrajet
« Reply #2 on: November 23, 2018, 05:48:56 PM »
F33 Durabond.
Blair Patrick
GJCAT427
« Reply #3 on: November 23, 2018, 06:33:19 PM »
Brent, yes the bores are grooved. Lifters were solids and the oil passages are not drilled. Blair I`ve been trying to get in touch with you, but the phone says message box is full. Garry
« Reply #4 on: November 23, 2018, 06:42:59 PM »
I was just making sure, but Blair beat me to it.
GJCAT427
« Reply #5 on: November 23, 2018, 06:50:14 PM »
Thanks guys Garry
