Author Topic: FE gasket sets  (Read 3137 times)
Pentroof
FE gasket sets
« on: November 20, 2018, 12:14:21 PM »
Is there a best way to source gasket sets without ending up with a pile of umbrella valve seals, internal water pump gaskets and head gaskets you'll never use?
I prefer the 1020 head gaskets, but I also need gaskets for the valve covers, oil pan, oil pump, timing cover, water pump to block. Also nice to have the foam for the inspection cover.
I guess I'm looking for a performance oriented kit and not a rebuilder. I generally end up buying the rebuilder kit and then source the head gaskets and better oil pan gasket separately.
Jim
JamesonRacing
Re: FE gasket sets
« Reply #1 on: November 20, 2018, 02:29:25 PM »
I have used a number of these kits:
https://smile.amazon.com/Fel-Pro-2720-Performance-Race-Gasket/dp/B000CMIRRE/ref=sr_1_16?ie=UTF8&qid=1542742061&sr=8-16&keywords=fel+pro+race
Since the head, intake, oil pan, and valve cover gaskets are more specific to the build.
Pentroof
Re: FE gasket sets
« Reply #2 on: November 20, 2018, 04:56:18 PM »
That works. Thanks.
I have a Prime account too.
Jim
