Author Topic: USA made .625 Rubber Valve Stem  (Read 4822 times)
winr1
« on: November 20, 2018, 10:43:53 AM »
Any know where I may purchase USA made .625 Rubber Valve Stems ??
Or, what is a good brand ??
Ricky.
Re: USA made .625 Rubber Valve Stem
« Reply #1 on: November 20, 2018, 11:22:45 AM »
???  Would you preview this and maybe give us some more information.  Never heard of a rubber valve stem.  Viton valve stem seals in .625" are available if that is your question.  Most auto parts houses have them or can get them.  Joe-JDC
« Reply #2 on: November 20, 2018, 11:27:09 AM »
Rubber valve stems give variable-flow.  :)
winr1
« Reply #3 on: November 20, 2018, 11:49:52 AM »
Heh :-)
For the rear wheels on my 65 F100
Ricky.
« Reply #5 on: November 21, 2018, 09:05:01 AM »
Would a bolt in style be sufficient?   That 5/8" hole is larger then typical I think, like for tubes.  I use them on most all my stuff.
winr1
« Reply #6 on: November 21, 2018, 09:27:56 AM »
Thanks guys :-)
I got a pair of each from Firestone, Discount tire and O'Reilly's ^_^
2 Dill, 2 Schraeder which have Chine marked on bottom
The Dill show to be made in Chine on the internet
2 from O'Reilly's are Xtra seal .....  made in Chine
TR415 are .625 hole....  normal passenger stuff is TR418, .453 hole
The wheels are 15" x 8", cut apart with a backspace of 3.75"
They have material added between the 2 halves
They center in my 65 F100 better than 4" backspace
Larry, I went to a few sites, they stated if driven a lot of miles the nut should be periodically tightened
I have no idea, but it seems a bit of lock tight would help
Ricky.
« Last Edit: November 21, 2018, 09:36:20 AM by winr1 »
GJCAT427
« Reply #7 on: November 22, 2018, 07:16:22 AM »
Ricky, I use the boltin type an all my cars and trucks. I get them a the local NAPA off the rack. I can`t remember the brand, they come in a green and white bubble package. They have 2 sizes of seals in the package. Haven`t had any issues and the set on my red truck have been on for 6-7 yrs now. I haven`t tightened them at all since mounting the tires.
« Reply #8 on: November 22, 2018, 08:14:49 AM »
I'm sure the warning about regular checking the nut is because of the rubber gasket and it growing/shrinking over time.  I haven't had any issues.  I suppose tightening them "just so" will make them survive forever.  You can't crush it, you can't leave it loose.  Maybe a dab of silicone on the rim before tightening the nut will hold it from backing out from any vibration?  I never have, but something to think about if you want to.
All large truck rims have screw on stems.  Although then are metal to withstand the 120# pressure, they are still bolt on.  I've had the Mack 17 yrs without ever worrying about the stems coming loose.
wowens
« Reply #9 on: November 22, 2018, 09:41:28 AM »
I use bolt in metal valve stems with rubber washers and no thread loctite.
Have never had a issue.
Woody
« Reply #10 on: November 22, 2018, 11:53:08 AM »
ECTA Land Speed racing requires metal stems. I had them mounted when I bought the tire-wheel package in the first place in 2007. The tires have been replaced several times but the wheels are still going strong and, so far as I know, the stems have never been touched. Discount Tire is a VERY good place to do business.
winr1
« Reply #11 on: November 22, 2018, 11:32:08 PM »
Alrighty then .... gonna use the bolt in type :-)
Thanks again guys !
Ricky.
