Author Topic: 2 inch wide leaf springs for 66 Comet??  (Read 15421 times)
Re: 2 inch wide leaf springs for 66 Comet??
« Reply #30 on: January 16, 2020, 10:51:19 AM »
I would skip the tophat the aluminium spacer ,weld the axle and drill new holes
in the right place
« Reply #31 on: January 17, 2020, 12:54:06 AM »
If you need to gusset the leaf spring perches, maybe an idea to replace the old ones with new 2" wide perches with the right size center bolt hole. Than you could weld the new perches at the correct pinion angle, and not need any tapered wedges.
Jim Comet
« Reply #32 on: January 17, 2020, 06:30:41 AM »
With the additional leaf spring I am not positive what I will need for a wedge to dial in my pinion angle. I believe I have come up with an idea that will work. It involves a new top plate that will locate on the spring bolt and have 2 studs that will hold the pinion angle wedge while protruding into the spring perch to locate the axle. Hard to describe but I will document it and post some pictures when I build them next week. Jim
Jim Comet
« Reply #33 on: February 29, 2020, 09:48:05 PM »
Well, after many trials and not wanting to put on new perches right now, this is what I came up with. I will monitor it over the summer and may decide next fall to just put on different perches. I made everything you see here and patterned this off of both CalTracs and the Assassin bars. Jim
« Last Edit: February 29, 2020, 09:56:31 PM by Jim Comet »
« Reply #34 on: March 01, 2020, 12:59:17 PM »
You probably could have welded an offset bushing into that spring pad center hole.  Make a 1/4" thick round disc with the hole offset to one side. Heat on that pad shouldn't warp the housing.
Jim Comet
« Reply #35 on: March 01, 2020, 02:13:57 PM »
Tom I believe you are right. If I have any future issues or concerns, I will probably just weld a plate to the bottom of the perch with the correctly placed hole.Jim
