FE Technical Forum
Block Filler
Topic: Block Filler (Read 3325 times)
hwoods
Sr. Member
Block Filler
November 01, 2018, 08:10:11 AM »
anyone add block filler to street driven FE Motor? Any advantage, dis advantage? Engine / car will see some track time Thanks
Previous FE Cars: 1965 Ford Galaxie 390/4spd then upgraded to 427 sideoiler
1970 Maverick 427 sideoiler. X Pro Stock Car, previous owner had a cammer in it but that was beyond my budget
Re: Block Filler
Reply #1 on:
November 01, 2018, 08:14:46 AM »
Yep, do it all the time. You will most likely need to run an oil cooler. It doesn't get the water hot, but it can cause the oil temps to bump up.
Instagram: brentlykinsmotorsports
YouTube: Lykins Motorsports
Re: Block Filler
Reply #2 on:
November 01, 2018, 08:45:37 AM »
As Brent said - for a street/strip car I would not. I didn't even do it in the dragster and that is pure drag only. If you decide to do it, do it before you do final hone on the block because it will distort the cylinders a bit.
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
Re: Block Filler
Reply #3 on:
November 01, 2018, 10:07:39 AM »
I have a half fill in my street 428. It seems to work fine. I've been driving it for over 10 years. I did put an oil cooler on it.
paulie
FE Technical Forum
Block Filler
