Author Topic: Will baldie covers fit over T&D race rockers?  (Read 5356 times)
« on: October 23, 2018, 09:28:41 PM »
I'm assuming that they will, because I don't believe the T&D race set sits any higher than normal FE rockers, but I have never used them, so figured I'd ask the guys on here. Has anyone tried that combo?
Re: Will baldie covers fit over T&D race rockers?
« Reply #1 on: October 24, 2018, 07:51:09 AM »
If they don't fit get some of the B&B VC spacers , I run a set on my "smoothie VC's " to clear Dove end stands , just a thought
« Reply #2 on: October 24, 2018, 08:58:45 AM »
I thought about them but would like to avoid using spacers if at all possible. I would think that if just about any of the standard FE valve covers clear the race set, that the baldies should work. Certainly somebody has tried a set of CJ covers or something similar to them? I'm guessing they probably had to remove the baffles, but that's not an issue with the baldies.
Anyone?
« Reply #3 on: October 24, 2018, 10:46:50 AM »
They fit
« Reply #4 on: October 24, 2018, 11:46:42 AM »
Thank you, Barry.
afret
« Reply #5 on: October 24, 2018, 12:24:04 PM »
With CJ cast covers, they fit the race rockers with baffles removed.
« Reply #6 on: October 24, 2018, 01:01:00 PM »
They also fit cast aluminum pentroof valve covers.
« Reply #7 on: October 24, 2018, 01:25:46 PM »
Thanks Earl and Brent. I may change my mind and use the CJ covers I have. It's nice to know I have the option of using a couple of original Ford covers.
