Author Topic: Best FE Clutch Fork, Pivot Ball, Adjustable Linkage Rod, Spring Kit ?  (Read 4496 times)
427HISS
Need everything for the clutch. High quality, no thin cheap junk !  (especially the fork)
Also, is there a direct fit fork/bell boot for the QuickTime bell ?
Just Called Summit and QuickTime/Holley,....says "racing cars don't need boots".   THANKS,... QuickTime !!! ?   ::)
Sorry but, that mentaility SUCKS !   >:(
So us guys that have performance car's and have safer sreel bellhousings on the street and/or race, don't want to keep the clutch & flywheel clean of debris, water etc ?
« Last Edit: October 02, 2018, 06:05:27 PM by 427HISS »
HvyFt4spd
Re: Best FE Clutch Fork, Pivot Ball, Adjustable Linkage Rod, Spring Kit ?
« Reply #1 on: October 02, 2018, 06:01:18 PM »
https://www.summitracing.com/parts/mcl-16935?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-mcleod-racing&gclid=Cj0KCQjwrszdBRDWARIsAEEYhre0-MKcTOiV7DJGml4vqgwFyG-vSWvt3sAbxKK7YPQ8TtgZkV8-y9IaAqzFEALw_wcB
https://www.summitracing.com/parts/qti-rm-6057
 I didnot find a listing for a pivot ball version so far but I
 had one American PowerTrain shipped by accident. In that case it appeared to use a regular boot but I did not fit one.
« Last Edit: October 02, 2018, 06:03:41 PM by HvyFt4spd »
wowens
« Reply #2 on: October 03, 2018, 05:35:37 PM »
I can't remember the exact part, but the last time I needed a boot, I bought a shifter boot that I thought would work from Dorman and modified it. Worked well.
Woody
427HISS
« Reply #3 on: October 06, 2018, 09:47:21 PM »
What mod did you perform?
Could you take a pic ?
427HISS
« Reply #4 on: October 07, 2018, 05:35:59 PM »
Do you buy your adjusting rod or fab up one ?
Who has the highest quality throw out bearing ?
« Last Edit: October 07, 2018, 08:15:35 PM by 427HISS »
Coreyc619
« Reply #5 on: October 12, 2018, 12:23:13 PM »
Clutch fork - any reputable transmission vendor, then weld a piece of flat bar down the inside of the concave side to stiffen up, if quick shifting is desired
pivot ball - in the linkage or in the bell?  Either way, I've always gone with fresh OEM parts in these areas, with no issues.
adjustable linkage - I made my own, and bought heim joints/lock nuts to put on each end.  This was a vast improvement in my case.  Half hour project if you have the material on hand.  I used 3/8"  threaded heims and bought a LH die so I could adjust it without unbolting one end.
427HISS
« Reply #6 on: October 14, 2018, 08:53:31 PM »
I like the  heim idea, so I'll  go to the store this week. Happen to have any pics though ?
