Author Topic: Mixing cam and Lifters  (Read 3404 times)
Dubs1
« on: September 17, 2018, 04:41:56 PM »
Am sure this has been mentioned before  but I forgot the answer.  Can you use a hydralic  flat lifter set   on a  roller cam.  Its in a car for the kid, a stock 302,  in a 68 FB.  Oiling  is unchanged  ie, lifter valley, juice lifters and feed to the rockers.  Had this 68 hipo cam laying around, new and unused.
Thanks much
JamesonRacing
Re: Mixing cam and Lifters
« Reply #1 on: September 17, 2018, 04:51:34 PM »
Not quite sure what you're wanting to do, but flat tappet cam lobes have a slight slope side to side so the lifter will rotate.  Roller cams don't have that feature, so the flat tappet cam would eat up the lobe in a hurry.  The ramps on the roller cams are often much steeper, which wouldn't be functional without a roller lifter.
Dubs1
« Reply #2 on: September 18, 2018, 09:02:42 AM »
Thanks Janeson
The cam is a mechanical flat tappet  not ground to be a roller.
« Reply #3 on: September 18, 2018, 09:07:04 AM »
Mixing is a good way to be back in the motor real quick.  Either run the lifters that match the design of the cam, or get a hydro flat kit with lifters.
This is a good all-round cam spec for a 302
https://www.summitracing.com/parts/edl-2122/overview/make/ford
