Author Topic: Lykins Motorsports TFS Headed 395FE  (Read 11451 times)
« on: September 15, 2018, 09:22:45 AM »
Performance Summary:
      Cubic Inches: 395              Dyno brand:  Stuska
      Power Adder: N/A              Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  538 @ 6000, Engine dyno'd with water pump and alternator connected
      Peak Torque:  515 @ 5000
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 390 block, 4.080" bore size, 10.150" deck height, ARP main studs/bolts
   Crankshaft brand, cast or forged, stroke, journal size:  Factory 391 crankshaft, 3.780" stroke, 2.200" rod journal
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat I-beam, 6.800", 8740 bolts
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Custom Racetec forged, 5.3 cc flat top, 10.4:1, .004" piston to bore
   clearance, pistons .008" out of hole
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Federal Mogul 125M10, Federal Mogul 8-7200CH & 8-7200CH1, Durabond F-33
   Piston rings brand, size, other notes:  Hastings 1.5/1.5/3mm, standard tension, .020"/.022" gaps
   Oil Pump, pickup, and drive:  Melling M57A, Canton rear sump pickup, POP pump drive
   Oil pan, windage tray, oil filter adapter:  Canton rear sump, no tray, new filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports hydraulic roller, billet core, 240/243 @ .050", 296/299 advertised, .555"/.579" lift, 109 LSA, on 103 ICL.
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Cloyes billet, factory timing cover
   Cylinder heads brand, material, port and chamber information:  Trick Flow, aluminum, 169.8cc port volume, 69.8cc chamber volume
      Intake               Exhaust
      .100  96             .100  66
      .200  159           .200  120
      .300  233           .300  164
      .400  283           .400  197
      .500  317           .500  215
      .600  333           .600  220
   Flow bench used, location:  Superflow SF600, Dale Meers Racing Engines
   Intake valve brand, head size, stem size:  Ferrea, 2.190", 11/32"
   Exhaust valve brand, head size, stem size:  Ferrea, 1.625", 11/32"
   Valve springs brand, part number, specs:  Comp Cams 26120
   Retainers and locks brand, part number, specs:  Comp Cams 1795
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Factory non-adjustable
   Rocker shafts and stands, brand, material:  New factory shafts, POP end and middle stands
   Pushrods brand, type, length:  Trend, 5/16", .105" wall, multiple lengths, 8.860", 8.875", 8.900"
   Valve covers, brand, type:  Ford Racing polished Cobra Lemans
   Distributor brand, advance curve information:  MSD Pro Billet, steel gear, 16/34, in by 2500
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Edelbrock
   Intake manifold brand, material, porting information:  Performer RPM, no port work, plenum divider and plenum modifications
   Carburetor(s) brand, type:  Quick Fuel Q-750
   Exhaust manifolds or headers brand, type:  Dyno headers, 2"
« Last Edit: August 16, 2020, 05:53:45 PM by blykins »
Re: TFS Headed 395FE
« Reply #1 on: September 15, 2018, 09:32:03 AM »
Oil pressure with Canton rear sump pan, 8 quart system volume, started at 68 psi @ 3500, increased to 78 psi @ 6500.  Valvoline VR1 10W-30, non-synthetic.
Main bearing journal diameters:
1 - 2.7385
2 - 2.7382
3 - 2.7384
4 - 2.7384
5 - 2.7382
Main bearing oil clearances:
1 - .0026
2 - .0030
3 - .0030
4 - .0027
5 - .0028
Crankshaft thrust clearance, .006"
Camshaft thrust clearance, .004"
Rod journal diameters:
1/5 - 2.1995"
2/6 - 2.1996"
3/7 - 2.1994"
4/8 - 2.1996"
Rod bearing clearances:
1 - .0024"
2 - .0022"
3 - .0024"
4 - .0022"
5 - .0025"
6 - .0024"
7 - .0023"
8 - .0025"
.025" rod side clearances
Distributor gear install dimension - 3.043"
Spring install height - 1.820", 170 closed, 395 open, .060-.080" coil bind clearance, .800" retainer/seal clearance
Spring coil bind distances:
1E  1.180"
1I  1.175"
2E  1.176"
2I  1.174"
3I  1.182"
3E 1.176"
4I  1.177"
4E  1.184"
5E  1.180"
5I  1.175"
6E  1.180"
6I  1.171"
7I  1.175"
7E 1.172"
8I  1.170"
8E 1.175"
.320" intake valve clearance with .051" gasket, .060" radial
preaction
« Reply #2 on: September 15, 2018, 09:58:33 AM »
Awesome build Brent what fuel did it need ?
« Reply #3 on: September 15, 2018, 10:02:14 AM »
93 octane.
« Reply #4 on: September 17, 2018, 05:47:51 PM »
Hey Brent was there a difference with or without the spacer. Did you run it with the dominator or is it just for photos
« Reply #5 on: September 17, 2018, 06:03:11 PM »
There was a pretty bad A/F ratio difference between sides without the spacer, so I put one on after the first pull and it straightened them out.  So all the pulls were ran with a 2" Super Sucker.
I ran it with both carburetors.  It made 538 hp with the Q-750 and 540 with the 1050 Dominator.
« Reply #6 on: September 17, 2018, 09:24:42 PM »
Just curious as to why the A/f difference from side to side, and that 750 really performed huh.
Were they both right out of the box.
« Reply #7 on: September 18, 2018, 04:59:14 AM »
It's not abnormal to see an A/F ratio difference between sides and it could be that my plenum divider caused a little of it.   Spacer straightened it out though.
The Q-750 took some HSAB and jet work to get it there but I didn't turn a screw on the Dominator.  To be honest though, throwing the Dominator on was just something we did at the last minute for giggles.  Sometimes you don't know what something will do until you try.
« Reply #8 on: September 18, 2018, 10:02:18 AM »
Thanks Brent great job
