Author Topic: Readings on 3 x 390 crank journals  (Read 4709 times)
winr1
« on: September 09, 2018, 10:12:28 PM »
#1 Mains: 2.715 ....... Rods: 2.418
#2 Mains: 2.725 ....... Rods: 2.425
#3 Mains: 2.713 ....... Rods: 2.424
All the journals look good, bearings were fine as well
Ricky.
Re: Readings on 3 x 390 crank journals
« Reply #1 on: September 10, 2018, 05:17:50 AM »
What did you measure with?
FrozenMerc
« Reply #2 on: September 10, 2018, 12:43:06 PM »
Not to put words in Brent's mouth, but what I think he is driving at is that it would be rather odd that some machinist would cut one of the mains at -0.020" and the others at -0.030".  You would then have to buy multiple sets of bearings and play the mix and match game.  So, are you sure you measured accurately?  Also, what were the rest of the journals cut at?  Do the bearing shells have their size marketed on them?  If so, do they match your measurements?
« Last Edit: September 10, 2018, 12:46:55 PM by FrozenMerc »
winr1
« Reply #3 on: September 10, 2018, 07:32:10 PM »
Starrett 2" to 3" mike, measured 3 times
As to each crank, all the mains and rod journals are the same
These came out of running engines and were not turned
Have had over 50 or 60 cranks with the mains and inserts different sizes under
#1 Mains: 2.715 ....... Rods: 2.418 ......  .034 under and .020 under
#2 Mains: 2.725 ....... Rods: 2.425 ...... .024 under and .015 under
#3 Mains: 2.713 ....... Rods: 2.424 ...... 0.36 under and . 014 under
The under numbers have given me pause
Ricky.
Lg57
« Reply #4 on: September 11, 2018, 08:37:33 AM »
To clarify, are you measuring three different crankshafts or different journals on the same crank? Sounds like you know what you're doing but I'm confused.
FrozenMerc
« Reply #5 on: September 11, 2018, 01:00:23 PM »
I am confused now too.  The way I read it yesterday was that you measured the first 3 journals on a single crankshaft and came up with different sizes between each of the first 3 journals.  Or was it as Lg57 implied that you measured 3 separate crankshafts and reported average numbers for the rods and mains?  In which case, what is the question?  0.0025" to 0.003" clearance is generally considered nominal, looks like you are at 0.004 to 0.006" on your mains.
« Last Edit: September 11, 2018, 01:05:21 PM by FrozenMerc »
« Reply #6 on: September 11, 2018, 04:39:14 PM »
If it's one crank - Sounds like a 400 I was given (some time way back) that came out of a service truck.  Ford Reman tag on the side.  Some bores were .030, some .040, , one .060, deck height varied by hole, some down .070, most around .050.  Never got to the crank, never broke it down - it went as a unit to the scrap yard for .017/lb.
winr1
« Reply #7 on: September 13, 2018, 03:04:09 AM »
Sorry guys :-)
There are 3 390 cranks... 2 are 2U and 1 2UA
The 5 crank journals are the same per crank
Same for the rods
#1 crank has all 5 mains at 2.715
#1 crank has all 4 rods at 2.418
#1 crank  Mains: 2.715 ....... Rods: 2.418 ......  .034 under and .020 under
#2 crank Mains: 2.725 ....... Rods: 2.425 ...... .024 under and .015 under
#3 crank Mains: 2.713 ....... Rods: 2.424 ...... 0.36 under and . 014 under
The under number is from an un turned crank
The clearances are what are odd .......... I cant find my mike pins to check if they are off
I will check and see if I need to calibrate my mikes :-)
Ricky.
« Reply #8 on: September 13, 2018, 07:10:00 AM »
I misread it originally too.
I think you need to check your mic though.  Consistent weird measurements across many cranks is usually due to the tool (LOL read that in any context and it is correct)
