Author Topic: 4R100 trans trouble  (Read 24041 times)
KMcCullah
4R100 trans trouble
« on: September 17, 2012, 12:10:19 PM »
The transmission in my 99 powerstroke is messed up. I took some stuff to my wifes office yesterday and when I went to leave, reverse was gone. But I still had drive. So I pushed it out in street and drove off. Then I noticed that 3rd and 4th gears were gone too. It just won't shift or the gears are gone. Anyhow, when I bought this truck the tranny was a year old and I've only had it for 8 months so I don't think it's worn out. Fluid looks good and smells good. I'm trying to figure out if this is something I can fix without dropping the trans. Like the valve body is screwed up maybe? I've did alot of reading on other forums but nothing definite yet. Anyways..... Automatic trannys are my weakness. Any wisdom you guys could pass along would be greatly appreciated.
Kevin McCullah
Re: 4R100 trans trouble
« Reply #1 on: September 17, 2012, 01:55:22 PM »
sounds like a direct clutch problem , could be a cracked piston , bad lip seal , hard to say .... the direct clutch is the only element common in reverse , third and fourth , trans will probably have to come out , you can try unplugging the electrical harness and see if you get reverse but I don't think you have a electrical system problem
KMcCullah
« Reply #2 on: September 17, 2012, 02:07:19 PM »
Well that isn't the answer I was looking for! lol Since posting this morning I've found more info. It sounds like I may be pulling the damn thing.
Sigh.......my 445 mud motor will have to wait.  :(
Kevin McCullah
KMcCullah
« Reply #3 on: September 18, 2012, 09:46:26 AM »
I found the reciept for the rebuild in the glove box. I called the guy who built it. Petes transmissions in Phoenix. This tranny was rebuilt 12/20/10. It was done on the cheap per the customers request. The whole job was done for $1800. Which is about half of what a diesel rebuild should be. The parts were where the scrimping went on. It would have been a suitable rebuild for a gas motor but not a high torque diesel.
So I'm going to pull it and get the HD4R100 at the Ford dealer. There goes my 445 mud motor build.
Sigh.............
Kevin McCullah
KMcCullah
« Reply #4 on: September 21, 2012, 02:33:28 PM »
ITS HEALED ITS HEALED!!!! And I don't know why. I spent alot of time looking. Checked all of the electrical connectors. Put the stock engine tune back withthe hypertec tuner etc. Nothing worked. Was home for lunch today and went out and fired it up and it fixed itself. I'm at a loss...... I'm suspecting the shift linkage may have something loose in the steering column.
Kevin McCullah
« Reply #5 on: September 21, 2012, 03:14:18 PM »
Alright!  Get that mud motor built before it breaks again LOL!
KMcCullah
« Reply #6 on: September 21, 2012, 07:30:38 PM »
 :) I'm back on it now.
Kevin McCullah
lovehamr
« Reply #7 on: September 22, 2012, 07:55:39 AM »
I love it when things fix themselves! ;D
« Reply #8 on: September 22, 2012, 12:11:56 PM »
Hmmm...Christine :o
lovehamr
« Reply #9 on: September 22, 2012, 05:34:25 PM »
Heo's got a point; has your truck told you to kill anyone yet?  :o
« Reply #10 on: September 22, 2012, 06:02:40 PM »
That's what we always called a 'wall' job. Park it over by the wall until it fixes itself!
KMcCullah
« Reply #11 on: September 24, 2012, 08:00:43 PM »
Toatally bizzarr!!!!I spent the weekend pulling a trailer loaded with scrap metal. Approx. 8000lbs. Not one complaint from the damn thing. I'm still leery of it though, because of what the guy who built the tranny told me. I'm gonna install a spin on filter kit and change to syn oil. I've already installed a 40,000 BTU cooler. I figure I'll show it some love and maybe it will last.
Kevin McCullah
FirstEliminator
« Reply #12 on: November 08, 2012, 11:51:06 PM »
Been a while since I have visited the site. Sorry for the delayed reply.
     No reverse 3rd and 4th and it fixes itself? Weird.  Sounds like a sticky valve in the Direct clutch line up in the accumulator body. My head was getting dizzy looking at the hydraulic diagram for reverse---there's a lot going on. 3rd was easier to trace. The accumulator valves seemed to be a likely candidate in common with both reverse and 3rd/4th.
   Sonnax makes a bore sizing tool for the accumulator body. Tool #36948-12.  I use it on every rebuild. Had the problem of a sticky accumulator valve once that burnt a fresh rebuild in an ambulance.  Usually the accumulator bores are pretty out of shape. Lately, I have been holding the tool in the vise and holding the accumulator body in my hands. It's a lot easier grip than holding the tool in my hand or bothering with a slide hammer to pull the tool out.
      If it was a budget rebuild on the trans, chances are the extra time to straiten out the accumulator valve bores wasn't taken. If you do buy the tool and pull the accumulator body, take a good look at the line pressure modulator valve. The sleeve wears pretty quick. If you see a polished look on one side of the inside of the sleeve, then the valve/sleeve needs to be replaced.  I usually go with the larger size valve Sonnax # 96948-01k. This valve measures .427. It will firm up the shifts a little bit over the smaller valves. There is also .500 valve, but Sonnax doesn't recommend this one for street use in diesels.
     Spin on filter and the cooler is a good idea.
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
KMcCullah
« Reply #13 on: November 09, 2012, 08:43:28 PM »
Mark- It's been working ok since it fixed itself. It has quite a bit of slip between shifts if I'm on the go pedal hard. I've been considering going back to the firm shifts with my Hypertec tuner but I've read it's hard on the pump. Then I've read it's hard on the clutches to not firm up the shifts. What do you think?
Is the accumulator body your talking about, also called the valve body?  I've found several performance diesel valve bodies online. Do you have a favorite?
Kevin McCullah
FirstEliminator
« Reply #14 on: November 09, 2012, 11:42:39 PM »
    Well, all the programmer can do is up the line pressure via the EPC solenoid. This is a partial solution. The accumulator springs need to be stiffer and the seperator plate needs to be drilled to allow more volume faster to apply the clutches. Adding more clutches per pack will increase surface area contact increasing holding capacity. Kinda like tubbing a narrowing the rear to get some 18" slicks under there---more contact patch = better traction. To have a good performing transmission you need to bring up the level on all those aspects---a well matched combination.
   High pressure causes things to wear quicker. Not just the pump, anywhere else pressure is routed through, especially sealing rings.
   Low pressure and volume will allow clutches to slip when attempting to apply. It wears the clutches faster, creates heat and pretty soon the clutches will get glazed over and then burnt. Holding power of the clutch pack is compromised and eventually nonexsistant.
   They might be talking about the accumulator body. The valve body doesn't have much effect on the intensity of the shifts. The main valve body has more to do with sending the fluid to the correct places. The accumulator body is where the shift intensity is controlled. If you see a picture, the accumulator body is retangle. It is all the way up front right behind the filter tube.
    Personally, I have never purchased a high performance V-B or Accu-B from a performance vendor. Where I live there isn't much high performance stuff going on. We've built some H-D diesel stuff choosing induvidule pieces and drilling the seperator plate to what we have found appropriate to the application. Some of these trucks would get sideways on the 1-2 shift and have a nice 2-3 and 3-4.  There are shops that performance trans is their only focus and they maximise the holding capacity of the trans. But, not sure who to recommend.
    If you want to make some moderate inprovements it isn't really a tremendous job to pull the valve body, accumulator body, solenoid and seperator plate. Then you can better match volume and pressures. The bad parts is, with just about any shift kit off the shelf they are going to want you to make mods to the pump, which is only accessable when the trans is out. If you are attempting to make some control mods yourself, I can send ya some info on where to drill and what to use.
Mark
68 Monterey 390 C-6
