Author Topic: aluminum heads and C3AE cast iron long tube headers  (Read 3323 times)
olman
« on: September 05, 2018, 01:31:36 PM »
Just wondering if the exhaust flanges on the aluminum heads are strong enough to support the weight of these heavy suckers.
Re: aluminum heads and C3AE cast iron long tube headers
« Reply #1 on: September 05, 2018, 01:49:42 PM »
No they are not.  Why don't you just send those archaic lumps to me and be done with your problems  ;)
Seriously, they should work great.  You may want to consider inserts in the exhaust flange bolt holes, or at least a bit of anti-seize, to be sure the bolts don't gall into the aluminum.  I'll let the other guys chime in about the best exhaust gasket for that combination.  Unlike iron-iron, I don't think you will get an acceptable exhaust manifold seal without a good gasket.
Best of luck!  Sounds like a fun build.
- Bill
ToddK
« Reply #2 on: September 05, 2018, 06:28:39 PM »
I ran a set of the C3AE long cast headers on a pair of Survival aluminum heads in my '63 Galaxie. They worked fine. I had the manifold faces machined flat and only used some high temp sealant, no gaskets. They sealed okay, no leaks and no problems with lots of street driving..
