Author Topic: Who says the little Y can't sip high octane?  (Read 6640 times)
« on: September 01, 2018, 01:53:54 PM »
Got the initial break in with no leaks, no drips, no errors.  Tried three new carbs, QF-750, BG-930, Holley 1150 Dom, and yes the Dominator made more torque and horsepower on the little Y.  Now for the tunnel ram and TWO QF-650's, or two QF-750's, or Holley 660's.  Looking good so far.  Joe-JDC
Royce
Re: Who says the little Y can't sip high octane?
« Reply #1 on: September 02, 2018, 10:50:54 AM »
Good going Joe,  Can't wait to see it perform.. I am sure you will have a razor sharp tune on it.. I am betting there is some more horsepower with the tunnel ram and 2x4..
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
« Reply #2 on: September 02, 2018, 12:00:47 PM »
Thanks, Royce.  It sure has been a fun project to build.  My garage is a mess right now.  It never ceases to amaze me how well the Y Block responds to modifications, and how strong it really is.  I am a little off in my camshaft selection, but it sure runs good.  If I could get it to peak a little lower in the rpm band, then it would be nearly perfect for the competition.  Joe-JDC
PS.  I have e-mailed you at least 5 times with no reply.  I don't know if my e-mails are getting through, or if there is still a problem with my carrier.
« Reply #3 on: September 02, 2018, 12:04:36 PM »
Really enjoy hearing from you gents that run Ys.
Hope you have fun with it.
Royce
« Reply #4 on: September 02, 2018, 12:10:19 PM »
Joe  I am not getting the emails..  I need to check the spam filters to make sure you are not blocked.
If you tell me what you are looking for lift and duration wise on a cam I might have one here that would fit.. Free to use it if you want to go to the trouble..
Most people will scoff when we comment on how Y Blocks can be made to perform so well without a lot of aftermarket support..  At the risk of being flamed, on a hp/cu in basis, Y Blocks are much easier to get power from than almost any other Ford engine..  As JC says:  "It is the magic of over/under ports"  LOL
1992 BMW V-12 5.0
Tommy-T
« Reply #5 on: September 03, 2018, 12:41:52 PM »
Looking good, Joe!
I was hoping to see that ancient YC tach drive Mallory distributor I gave you on that Y. ;)
Go get 'em!
« Reply #6 on: September 03, 2018, 03:09:10 PM »
Yes, I considered that distributor, but the new MSD won out due to the two wire, MSD 6AL, Coil, etc.  Have to mount everything on a small piece of aluminum and attach to the rear of the engine block/bell housing.  Going back to the dyno on Wednesday for tunnel ram testing and hopefully set a new NA hp level for a few days until Ted gets his engine up and running.  Jon K's doesn't count since it had non-stock port heads on that engine.
Royce
« Reply #7 on: September 03, 2018, 04:38:16 PM »
Joe,, Do you have the engine sitting in front of the T Bird so they can get acquainted for an eventual union?
1992 BMW V-12 5.0
« Reply #8 on: September 03, 2018, 09:03:34 PM »
Actually, I am in the process of building a 346 Y with iron heads and vintage intake for the '55.  The 3 x 2 dyno session got my attention with the Edelbrock 573 and Big Bore Strombergs, and I still have the Edelbrock 255, 257, and Ford 8V to test.   The 375 Y is 13:1 as it sits, and that is just not street friendly.  Still looking for another '56 to beat on with 375 Y.  Joe-JDC
falcongeorge
« Reply #9 on: October 31, 2018, 08:38:46 PM »
Never thought I'd see a y-block with a dominator on it.  :)
