Author Topic: Printo seals strike again  (Read 4913 times)
fastback 427
« on: August 26, 2018, 06:48:09 PM »
My intake gasket has been seeping on the outside of my head all year. Finally pulled the intake and found the printo leaks are saturated and not even stuck down in spots. Plugs have been getting oil fouled and it is running way to rich.
Looking to do a cam swap and change the dove intake for a street dominator.
What is a good intake gasket for medium riser ports?
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
Re: Printo seals strike again
« Reply #1 on: August 26, 2018, 07:07:23 PM »
I like the Mr. Gasket 202A myself...
« Reply #2 on: August 26, 2018, 07:15:41 PM »
That's what I use too, on my ported Edelbrocks.   The Mr. Gasket 202A's.   I have to cut them to fit my enlarged ports, but I've never had an issue with them.
I took the Printoseal challenge a long time ago with horrible results......
JMO,
paulie
wowens
« Reply #3 on: August 26, 2018, 07:21:48 PM »
202a's, been around a long time cause they work
Woody
« Reply #4 on: August 26, 2018, 07:34:06 PM »
202As are all I use on a med riser, and cheap blue standard Felpros on a low riser
« Reply #5 on: August 26, 2018, 08:09:20 PM »
The Fel-Pros with an "S-3" suffix will work.  The passenger car MS10945 will work.  The aforementioned Mr. Gaskets will work (although the sealing area gets pretty thin on ported stuff).  Blue Thunder gaskets work really well (when you can get them).  The old Victor Reinz gaskets work if you still have some laying around.  Anything but the basic Print-o-seal seems to do OK.
fastback 427
« Reply #6 on: August 27, 2018, 02:49:39 PM »
Thanks for the input guys. 202's on the way.
Jaime
top end toploader
