Author Topic: 1966 Fairlane GT Shock tower clearance.  (Read 6968 times)
GTwayne
« on: August 19, 2018, 12:06:37 PM »
I have perhaps painted myself into the corner...
I purchased a "Estate sale" Fairlane with no motor or transmission, planning to go with a small block based 427.
But emotions got the better of me and a neighbor sold me a FE 427 with no heads. That said I just read that not all heads will fit in the
'66 engine bay. The internet is full of truths for sure but will a set of E'brock heads fit without cutting the towers? Thanks for any REASONABLE
response and if it can't be reasonable make it funny cause hate don't leave the gate.
wowens
Re: 1966 Fairlane GT Shock tower clearance.
« Reply #1 on: August 19, 2018, 01:13:00 PM »
I'm not sure about Ebocks, but every 66 I put headers on needed surgery, BUT if you get frustrated, I'm looking for 66 manual car.
Woody
GTwayne
« Reply #2 on: August 19, 2018, 02:02:11 PM »
I will keep that in mind, but at this point the Idea is to finish it.
Thanks for the update though.
« Reply #3 on: August 19, 2018, 03:40:20 PM »
1966 Fairlanes came with a FE as an option, so they will fit.  Most headers for that chassis have the 8 bolt or GT patterns.  The GT pattern is slightly different from the CJ, but you can order the headers to match whatever head you choose, and that is what I would consider.  The Edelbrocks seem to work fine with just the 8 bolts on the exhaust, so not an issue in my opinion.  Joe-JDC
cattleFEeder
« Reply #4 on: August 19, 2018, 07:34:02 PM »
Oh they fit tight, but  just do tranny headers as a unit and you will be fine.
Remember, RPM is your friend
cattleFEeder
« Reply #5 on: August 19, 2018, 07:37:10 PM »
These are FPA headers they fit, do not try dougsheaders they don't.
wowens
« Reply #6 on: August 19, 2018, 08:46:18 PM »
The FPA  headers look easy
Woody
GTwayne
« Reply #7 on: August 20, 2018, 04:08:07 PM »
OK, now I need a cigarette.....
6667fan
  • Every Second Counts
« Reply #8 on: August 22, 2018, 10:16:09 AM »
Those FPAs look nice n easy with an auto. But where they wrap tight to the block below number 8 is right where the cross shaft mounting block goes for a stick car. JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
fairlaniac
« Reply #9 on: August 30, 2018, 04:57:56 PM »
I had FPA's in my '66 when it had it's original C6. I then switched to toploader 4 speed with oem parts. The swing of the lower part of the z-bar did hit the headers. I took the pin out and moved it back 3/8" and shortened the z-bar. Never noticed a difference in operation. The worst issue I had was the power steering. It melted the boots, even when I added a drop bracket and then a 5/8" thick spacer. I realized then the headers were more important to me. I went to manual steering. Over 10 years of driving it this way.
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
gdaddy01
« Reply #10 on: August 30, 2018, 05:35:23 PM »
and got rid of the leaking fittings , lol
« Reply #11 on: September 04, 2018, 08:24:49 AM »
Apparently the FE header makers work hard on the tuck around the towers and bell.  I could never drop in a 351C with Super Comps on it - no way the tubes clear everything.  Especially on a Mustang, it's a bitch to get the headers in.  Falcon not so much even with the motor in place.
« Reply #12 on: September 04, 2018, 05:27:55 PM »
i have used hooker super comps on a few 390-428 66 fairlanes and 66 comets with minimal issues,but dont get me wrong,they take a little time and tinkering with to get them on ,but they do go on.the pass side 2 piece goes on easy,but you have to use tall tires on the front and a good set of springs to get good ground clearance.thats also why i put the battery in the trunk and use alu heads intake and water pump too,for the extra ground clearance
