Author Topic: Intake manifolds  (Read 3442 times)
1968Torino
Intake manifolds
« on: August 12, 2018, 04:33:52 PM »
FE 3x2 intake. Intake only. Missing the heat shield. The heat riser passage has a couple of small hole that will need repaired if using the carb heat. One on top and one on the bottom. $400
I have 2 351c holley strip Dominator’s. One is polished and the other is as cast. Neither has been ported and all threads are good. You pick which one you want. I’m keeping one because I still have a project getting a Cleveland. $500
Weiand tunnel ram for 351c. 1994. Drilled and tapped for a fogger. Otherwise it is not modified. Will need new gaskets for the top. $350
Offenhauser Port-o-sonic 351c 4v. I believe it is as cast. All threads are good. $150
My pics are not formatted to be posted on this site. I have a lot of pictures of the intakes and can email or text them to you. All prices are plus the ride. Things have changed in the last year and a half and it’s time someone else makes use of them.
Kitchen557@gmail.com
512-970-7105
It's a love hate relationship!
Jim Kitchen
