Author Topic: 67 c6 leaking out of band adjustment bolt?  (Read 3737 times)
stroked67
« on: August 10, 2018, 09:53:33 PM »
Noticed a couple drips of tranny fluid on my garage floor the other day. Tracked it down to being the band adjustnent bolt.  Ive never had this issue with a c6 before, what could this be caused by? Is it a problem deeper in the trans or just simply a bad locknut or adjustment bolt?
Re: 67 c6 leaking out of band adjustment bolt?
« Reply #1 on: August 10, 2018, 11:07:13 PM »
The locknut has a rubber seal integral to it. It’s customary to replace it during a rebuild. Shouldn’t be hard to find one.
« Reply #2 on: August 11, 2018, 10:18:18 AM »
As Drew said, replace the nut. Ford designed them to be 'one-use-only'.
stroked67
« Reply #3 on: August 11, 2018, 01:32:16 PM »
Sounds good, i will get a replacement asap!
FirstEliminator
« Reply #4 on: August 11, 2018, 03:03:46 PM »
Back off the nut a few threads, clean with some brake clean and put a dab of RTV under the nut.
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
