FE Technical Forum
Tunnel port 4BBL carb model #
Topic: Tunnel port 4BBL carb model # (Read 2917 times)
GJCAT427
July 26, 2018, 05:19:30 AM »
What Holley was used on the single 4 bbl version of the Tunnel Port? I`m going with single carb and the .600 lift cam on the new motor for the Galaxie.
gt350hr
Re: Tunnel port 4BBL carb model #
Reply #1 on:
July 26, 2018, 11:15:08 AM »
"Crate engines" Ford sold back in the day came with a C5AF 9510 BV 780cfm 'Lemans" bowl vacuum secondary carb same as the Medium Riser used.
FE Technical Forum
