Author Topic: What size block core plugs and how to seal them?  (Read 11614 times)
« on: July 24, 2018, 07:25:44 AM »
What size core plugs do you engine builders use, and how do you seal them when you install them? I'm talking about the block water jacket plugs. I'm assuming I can find them in McMaster Carr or something similar and need to get them ordered. I know this was discussed in Mr. Foxwells engine build thread, but apparently he didn't want to be helpful to anyone and had all his threads deleted. ::)
Re: What size block core plugs and how to seal them?
« Reply #1 on: July 24, 2018, 07:58:02 AM »
Doug, are you referring to the drive-in freeze plugs?
« Reply #2 on: July 24, 2018, 08:17:12 AM »
Yes, the ones that go into the side of the block.
« Reply #3 on: July 24, 2018, 08:39:45 AM »
We use 1-49/64 brass plugs with TA-31 silicone (you can use any of your favorite sealers - they all work - I know some guys even use epoxy)
C6AE
« Reply #4 on: July 24, 2018, 11:41:13 AM »
I use the 49/64 brass plugs and loctite...
« Reply #5 on: July 24, 2018, 01:09:40 PM »
Thanks for the replies. In case anyone is interested, the Dorman part # is 565-036. My local Napa couldn't get them, so I ordered them through Summit, in a package of 10. I always have a couple tubes of TA-31 around since that's what I use on most gaskets.
CaptCobrajet
« Reply #6 on: July 25, 2018, 08:54:05 PM »
I don't use any type of silicone there.  It just lubricates it good for exit!  Clean well and green Loctite. (sleeve retainer)
Blair Patrick
« Reply #7 on: July 25, 2018, 10:21:32 PM »
I know where to borrow a proper-size tap, so I thread them, use brass plugs and put them in with epoxy. (Extra support by doing so.)
« Reply #8 on: July 26, 2018, 04:54:28 AM »
I use silicone.  I've been using Dow Corning 732 for a few years now for pretty much everything.  Little bit around the outside edge, drive her in, and I'm done.  I can't recall ever having a freeze plug come out, but I've had a few blocks where the holes were a hair oversized for some reason and I've had to use metric plugs.
GJCAT427
« Reply #9 on: July 26, 2018, 05:14:00 AM »
I`ve used good ole Permatex aviation sealer (the brown stuff) for years. Never had one pop out yet. I got my core plug from Pioneer and got the ones for FEs by correct size.
« Reply #10 on: July 26, 2018, 01:46:49 PM »
X-2 on the Permatex sealer.  Joe-JDC
« Reply #11 on: July 26, 2018, 02:18:38 PM »
By all means, use the brass plugs. I had a steel one rust through once on a 460, behind the engine mount. Bitch to fix it!
C6AE
« Reply #12 on: July 26, 2018, 09:00:35 PM »
Put a magnet to those " brass" plugs.
More than once I have been sent brass plated plugs...
66FAIRLANE
  • Andy
« Reply #13 on: July 26, 2018, 10:07:45 PM »
Thats good advice right there!
427Fastback
« Reply #14 on: July 26, 2018, 11:25:22 PM »
Personally I would never use silicone on them for the stated reasons.I would use permatex or gasket cinch on them.That being said I have never had one come out regardless of what was used when they were installed.
1936 Diamond T 212BD
1990 Grizzly pick-up
