Author Topic: anyone on here ever make headers?  (Read 9284 times)
andis65
« on: July 22, 2018, 02:21:14 PM »
greetings- my question is basic- online they sell FE header flanges but most of them (patriot H7829 for example) do not come with the stub pieces that adapt the rectangular port shape to the primary round tubing. anyone on here ever fabricate from this point? how did you do it?
Re: anyone on here ever make headers?
« Reply #1 on: July 22, 2018, 02:56:11 PM »
Just fab yourself up a little tool.
These photos should be pretty self explanatory.
Some round stock in between whatever size thick tube (split) or channel you need. Then slap one end in a vise, apply elbow grease and swish bam boom, custom stuff.
« Last Edit: July 22, 2018, 03:29:42 PM by turbohunter »
gdaddy01
« Reply #2 on: July 22, 2018, 05:32:43 PM »
that is a cool tool , you should put that on the home made tool forum .
GJCAT427
« Reply #3 on: July 22, 2018, 05:57:26 PM »
I did something similar with a rectangular piece of barstock and ground it to shape. I them used a hammer to drive it in the pipe and left it longer than I needed to make the ends.
hwoods
andis65
« Reply #5 on: July 22, 2018, 08:24:42 PM »
wow, thats incredible forming tool turbohunter! and that master kit is turnkey hwoods! thank you!!!
HvyFt4spd
« Reply #6 on: July 23, 2018, 05:24:07 PM »
 That is a really cool way to do it. I usually make a pair of dies that replace the vice jaws and just reverse it. In other cases a simple male press die and a stop if not just a distance mark for repeatability. It's more setup but often faster production depending on the design needed.
babybolt
« Reply #7 on: July 23, 2018, 06:24:39 PM »
If your making headers for a car that has a steering box sitting right besides cylinder #8, the tube will need to make a sharp turn right outside the header flange.  I bought a set of off the shelf headers to get this turn, and just cut up the header for parts.
66FAIRLANE
  • Andy
« Reply #8 on: July 24, 2018, 08:20:57 AM »
Here be mine. Great tool Turbohunter!
« Reply #9 on: July 24, 2018, 11:27:48 AM »
LOL, no but I know a guy that does.
KMcCullah
« Reply #10 on: July 24, 2018, 02:19:56 PM »
The round peg in the square hole isn't too bad to deal with once you try it. Turbohunter's swaging tool looks pretty effective. Edit: I see now its a squeeze type of tool. What a badass simple tube jig!
 I just squeezed the tube in a vise to get two sides close. Then leave it in the vise and use a C-clamp to squeeze it square. Use a small gas welding tip to heat the tube in the corners. Make em red and hammer to fit the flange.
« Last Edit: July 24, 2018, 10:15:46 PM by KMcCullah »
Kevin McCullah
« Reply #11 on: July 24, 2018, 09:31:33 PM »
Answering your question, yes, I did make a set of headers once. But the stubs to fit the port shape came with the flanges. The way I've seen the stub shaping done, is by the method mentioned, where a spud is hammered into the end of the round tube to create the squared-off shape. The spud was made on a belt sander and case-hardened.
« Reply #12 on: July 24, 2018, 10:21:26 PM »
Kevin you were right about the Bridgeport.
Just happened to have one handy. Figured most don’t so I know a nice vice will take care of it too.
Have to thank a friend for the idea. Some guys just see things.
« Reply #13 on: July 25, 2018, 12:12:28 AM »
Don't make stubs... why? It makes a messy job having the extra welds and most car headers have no space for tubes to go straight out from the ports.
 I shape the tube, usually a J bend cut in half, even on the curve, quite easily with a hammer and vice.  Hammer one corner to a 90 degree point, check to see if the tube aims where you want and adjust the corner up or down. The tube can be squeezed in a vice to flatten the sides and then tap in the ends, put them in the vice and flatten (edit, the C clamp idea is better) and fine tune the shape by hammering over the edge of an anvil or steel block.
 By the way Turbohunter, where did you get those nice looking flanges? Many aftermarket ones come with way too small ports. Yours is what they should make.
« Last Edit: July 25, 2018, 12:20:32 AM by TomP »
« Reply #14 on: July 25, 2018, 07:54:09 AM »
Specialty Products Design out of Rancho Cordova, Ca.
http://www.spdexhaust.com/index1.html
My brother turned me on to them. Nice folks. They do little extras like bevel the edges. The fit is tight as a tick.
