Author Topic: 67 Mustang Fastback build  (Read 51755 times)
67 Fastback
Re: 67 Mustang Fastback build
« Reply #30 on: January 15, 2013, 12:31:00 AM »
photos
67 Fastback
« Reply #31 on: January 15, 2013, 12:36:01 AM »
photos
« Reply #32 on: January 15, 2013, 12:38:32 AM »
OOOOH!   That is purdy :-)
fe66comet
« Reply #33 on: January 15, 2013, 11:20:05 AM »
Yup one sweet pony engine ready to stomp camaros LOL
67 Fastback
« Reply #34 on: January 30, 2013, 09:47:49 PM »
Have made progress and got  the engine and gearbox fitted yesterday .Stripped valve covers and aircleaner for more room .Wrapped the top end in glad wrap to keep it clean .A few photos more to come .
« Reply #35 on: January 30, 2013, 11:37:42 PM »
Beautiful, just beautiful.
I want.
67 Fastback
« Reply #36 on: February 01, 2013, 05:18:18 AM »
Got some time to fit tailshaft and had to modify strut mount as the aircleaner was touching .Hope to fit up extractors saturday.
TimeWarpF100
« Reply #37 on: February 01, 2013, 07:58:46 AM »
Looks great!  What about hood clearance?
67 Fastback
« Reply #38 on: February 04, 2013, 02:59:42 PM »
Everything clears fitted up the left bank extractors it is tight in there.my son and I made up a alloy fuel tank Saturday it is baffled and has a inbuilt pot for the pump to sit in.will post some photos soon.
67 Fastback
« Reply #39 on: February 05, 2013, 08:04:30 AM »
Fuel tank being trial fitted before welding top in place .
« Reply #40 on: February 05, 2013, 01:52:26 PM »
Never had an FE in a mustang before. How do you guys deal with headers vs shock towers? Looks a bit tight.
« Reply #41 on: February 05, 2013, 03:42:41 PM »
"Tight" is an understatement, but it can be done.  Lots easier to install the headers while the engine is going into the car than to try to get them on with the engine bolted in place.  Ground clearance is another issue.  I'd go with FPA tri-Y headers for ground clearance reasons.  Test fit them with the engine and trans hooked together in case you need to grind anything (a block boss, transmission case, etc.) to make them fit, and then install them with the engine/trans.  Usually I can get those installed with the driver's side header bolted on from the start, and then after the engine and trans are in position but still up off the mounts by 6" or so, bolt the passenger side on, then drop the engine down onto its final position.
67 Fastback
« Reply #42 on: February 06, 2013, 02:30:53 AM »
Jay the biggest issue i had was clearance around the power steering box i have fitted in the car .Lucky i have small hands and time .The right side looks ok so should'nt be a problem .
« Reply #43 on: February 06, 2013, 08:13:13 AM »
Yes, seems like there is always some issue that you have to work through with header installs...
fe66comet
« Reply #44 on: February 06, 2013, 10:22:09 AM »
The headers I am proposing to use ( Doug's 627 ) come with a list of mods like tower, steering and possibly others.
