Author Topic: Found: Wanted Spicer 5831-E  (Read 5481 times)
chris401
« on: July 16, 2018, 03:43:19 PM »
Preference in order E, A OR C. I found a Watson 41 M1 but it looked kind of weak for my FE. If there is another design of smaller 3 speed that I am not aware of I would like to know more. A 7XXX series is too big for my use. Below is a link with a Spicer chart of the ratio's I want.
Thanks
http://www.6066gmcguy.com/spicer-5831-b.html
« Last Edit: August 04, 2018, 06:47:41 PM by chris401 »
NIsaacs
Re: Wanted To Buy A Spicer 5831-E
« Reply #1 on: July 16, 2018, 07:33:18 PM »
We bought a 7041 from this outfit a few years ago, it was an excellent unit. http://www.andersonbrotherstruck.com/
Nick
chris401
« Reply #2 on: July 17, 2018, 01:17:49 PM »
Nick
Thanks for the reference. They have it posted on the hotline.
chris401
« Reply #3 on: July 25, 2018, 11:29:39 PM »
I found a 5531-A. More to come...…..
NIsaacs
« Reply #4 on: August 02, 2018, 04:49:41 AM »
Coolness, keep us posted. Do you know the ratios? I think the 5531 was a pre-5831. It might be 1.52:1, 1:1, .72:1.
Nick
chris401
« Reply #5 on: August 04, 2018, 06:45:59 PM »
Nick
Yes that is the ratios. The A has a little deaper underdrive than I wanted but it will work. I won't need to split gears but it will keep third gear about where I like it and a decent overdrive when I am running empty.
3.54 axle=
5.38 under
3.54 direct
2.55 over
NIsaacs
Re: Found: Wanted Spicer 5831-E
« Reply #6 on: August 05, 2018, 04:57:17 AM »
Dang, 2.55 is pretty tall for a gasser. What size rig is it going in and engine build? What are you going to tow? I had a '79 Ford F-250 4x2 with a 400M, c-6 and 3.07, it wouldn't pull the hat off your head. After I installed the aux. in my F-350, I went from a 4.10 to 4.56, however it was setup for the log woods, steep hills and heavy loads. What I found was 3rd and over was a power house gear but caused 3rd/main box to overheat. I used up several NP435's and B/W T18's
Nick
fomocoloco
« Reply #7 on: August 12, 2018, 06:39:16 AM »
there is one currently on kansas city craigslist auto parts.
jim
8 65-72  f100 sb trucks 5 428's 1 460 2 521 strokers
1 66 f100 lb ranger sold
3 67-75 f350
numerous parts vehicles and parts
88 tbird 482ci 427 stroker 6R80 project
chris401
« Reply #8 on: August 12, 2018, 06:46:11 PM »
Nick
Commented in the NON Discussion section.
