Author Topic: Valve stem seals  (Read 3221 times)
Katz427
Valve stem seals
« on: June 30, 2018, 03:32:46 PM »
Well , this is not an FE, instead AFR heads on 351 SBF. The valve stem seals are gone after about 1200 miles. Looks like many did not stay seated on the guide and consequently were destroyed.
Anyone have a preference for the stem seals?
Re: Valve stem seals
« Reply #1 on: June 30, 2018, 03:40:22 PM »
I buy Viton seals from US Seal in bulk, but if they didn't stay put, and were the right size for the guide, I would look close to make sure the inner spring isn't hitting them or your retainer design isn't hitting at max lift.
Katz427
« Reply #2 on: June 30, 2018, 07:38:24 PM »
I don't believe the heads were touched, basic AFR package of springs, seals, retainers. I will check . Just checking comments on AFR and Summit racing, a few have had the problem.
