Author Topic: Rocker arm stud/ valve cover fittment  (Read 3847 times)
hwoods
« on: June 29, 2018, 12:59:06 PM »
I have a set of tall Mr Gasket valve covers.  supposed to be 4" tall.  I have a set of Survival Motorsports Heads, with the Edlebrock/ARP rocker arm studs.  The studs extend appx 7/8" above the rocker arm stand, keeps the valve cover from fitting down on the head?
is this a typical ocurance?  I would like to get this motor buttoned up
Thanks
19cougar68
Re: Rocker arm stud/ valve cover fittment
« Reply #1 on: June 29, 2018, 03:18:27 PM »
Medice Mfg makes the tallest valve cover spacers I have seen at 1.0" tall.
http://www.medicemfg.com/products_get.php?c=Valve%20Cover%20Spacers%20-%20Ford
« Reply #2 on: June 29, 2018, 04:49:00 PM »
Stack two gaskets together and see if that works.
« Reply #3 on: June 29, 2018, 05:05:28 PM »
« Reply #4 on: June 29, 2018, 05:21:02 PM »
Or shorten the offending stud?
Might just be one hitting a fill baffle - mark it and see.
Sometimes you can just cut a clearance hole in the baffle...
