Author Topic: Main cap dowelling  (Read 6357 times)
Chad D
Main cap dowelling
« on: August 24, 2012, 12:47:01 PM »
Anybody try this for an FE, or are studs deemed to be good enough to prevent cap walk?
Re: Main cap dowelling
« Reply #1 on: August 24, 2012, 07:32:11 PM »
Robert Pond's blocks have dowels to position the main caps, and the Shelby blocks have a wide area on the main stud that is a close tolerance fit to the hole in the cap, essentially serving as a dowel.  I have never seen a stock FE block with dowels installed; normally if someone upgrades a 2 bolt block they go to a cross-bolted setup.
