Author Topic: NIB McLeod 75211 Clutch Kit...  (Read 7035 times)
« on: June 09, 2018, 06:25:18 AM »
McLeod Super Street Pro 11" Long pressure plate, organic/ceramic disc, 1-1/16x10, and throw out bearing.  Rated for 500-525 hp.
Regular $435, will sell for $335 + shipping.
bluef100fe
Re: NIB McLeod 75211 Clutch Kit...
« Reply #1 on: June 14, 2018, 06:34:32 AM »
Brent,
Is this a button style ceramic disc clutch that would work in front of a NP435? If so I'm interested. Let me know, thanks,
Cody Ladowski
Straightline Machine LLC
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #2 on: June 14, 2018, 07:31:27 AM »
Cody,
It's a full face disc, with organic material on one side and ceramic/sintered material on the other side.  It will work with an NP-435.
bluef100fe
« Reply #3 on: June 14, 2018, 06:45:37 PM »
Brent,
Would it be possible to get a more aggressive clutch disc? Looking for something to hold 700ish hp and be somewhat streetable. If you have something to fit that bill let me know... I'm still interested in this deal also for my mud/street truck.
Thanks,
Cody
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #4 on: June 14, 2018, 06:59:06 PM »
Anything streetable for 700 hp would need to be a twin disc.  An RST twin disc would drive like a Honda but would hold 800 hp.  They are $800 with a throw out bearing.
bluef100fe
« Reply #5 on: June 17, 2018, 04:53:28 AM »
Brent,
The clutch kit is $800 or just the disc and bearing? I'm in need of a pressure plate also. What's a person use for a clutch fork with that setup? I have a steel flywheel that a stock clutch bolts to and a old Lakewood bell,is all I've collected so far. Thanks again
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #6 on: June 17, 2018, 06:20:17 AM »
That's the whole shooting match.....
The RST is sold without a bearing for $750 and then a McLeod TOB is $50.
The RST will bolt to any FE flywheel, fits in any bell, and you would use a standard small input clutch fork with it.
« Reply #7 on: July 14, 2018, 08:59:16 AM »
TTT....still for sale.
gdaddy01
« Reply #8 on: July 17, 2018, 06:21:30 PM »
how much effort to mash the clutch pedal in a 1967 mustang with stock set up ? I changed mine out from stock to a ram street -strip , now I can not drive the car much , because of clutch ,pressure plate pressure
« Reply #9 on: July 18, 2018, 04:09:03 AM »
The pressure plate clamping force is about 500 lbs lighter than the RAM.  I have never had any complaints about pedal pressure from the McLeod kits.
gdaddy01
« Reply #10 on: July 19, 2018, 06:18:46 PM »
Just to be clear in my head , this is for an 390-428 with a wide ratio transmission , long pressure plate and will fit inside a scatter shield and can be driven on the street ? thank you       ronnie adkins   how much is shipping to altha fl. 32421 ?
« Last Edit: July 19, 2018, 06:29:02 PM by gdaddy01 »
« Reply #11 on: July 19, 2018, 06:31:59 PM »
Yes sir.
$20 will ship it.
