Author Topic: Trick Flow Valve Spring Package....  (Read 5005 times)
« on: May 16, 2018, 05:04:56 PM »
Have been assembled on heads, but changed springs before heads were bolted on.
Trick Flow (made by PAC) 16094 dual springs, 1.545", 150 @ 1.950", 400 @ 1.350", CB @ 1.170".
Come with locators, locks, and retainers.
Retail price is $390.  I'll take $250 for it all.
chilly460
Re: Trick Flow Valve Spring Package....
« Reply #1 on: May 16, 2018, 07:59:27 PM »
How would these work with that 247/256 SFT I bought from you a month or so ago?
« Reply #2 on: May 17, 2018, 05:12:11 AM »
The spring pressures are about what I would use for a 6500 rpm engine with EDM lifters, but the only concern I have is the install height.  Most factory FE heads don't set up at 1.950", unless they're running a +.100" tool steel or titanium retainer.
I basically have the whole package priced for the price of the valve springs alone, so it wouldn't be a total wash for you, but my guess is that you'd end up switching retainers to get the install height high enough.
chilly460
« Reply #3 on: May 17, 2018, 06:26:36 AM »
OK, probably hold off for now.  Most likely will just go with valves and locks/retainers out of my Edelbrocks and I'll ping you for springs once I get the valve job done on my heads and know IH.
« Reply #4 on: May 17, 2018, 07:04:10 AM »
I would watch about using the standard package Edelbrock retainers/locks for a higher horsepower/rpm build.  The locks/retainers that they use are standard 7° "rebuilder" stuff.    Not very high quality for a hipo build.
Re: Trick Flow Valve Spring Package....SOLD
« Reply #5 on: May 17, 2018, 08:13:53 AM »
Sold to chilly.
