Author Topic: Pin for Distributor Gear  (Read 4204 times)
Cyclone03
« on: May 07, 2018, 05:12:41 PM »
My new roller cam requires a Distributor gear change ,what is the drill size and what pin should I install?
Lance H
Re: Pin for Distributor Gear
« Reply #1 on: May 07, 2018, 07:44:13 PM »
You can use a 3/16” roll pin.  It will require a 3/16” drill.
scott foxwell
« Reply #2 on: May 07, 2018, 08:12:38 PM »
I think the stock pin is 1/8". The one in my MSD was...I did a gear change this last weekend.
Cyclone03
« Reply #3 on: May 07, 2018, 08:37:32 PM »
Is there such a thing as a "good" roll pin?
Lance H
« Reply #4 on: May 07, 2018, 10:36:12 PM »
I often dbl pin .
« Last Edit: May 07, 2018, 10:39:59 PM by fekbmax »
rockhouse66
« Reply #5 on: May 08, 2018, 06:36:57 AM »
Yes, use a coiled pin.  Much stronger.  You can buy them by the bag in different diameters and lengths at McMaster Carr
Jim
gt350hr
« Reply #6 on: May 08, 2018, 10:06:04 AM »
  The key is good press on the gear itself. The roll pin will shear if the press is too light or non existent.
