Author Topic: WTB - 427 center oiler blocks - C4ae-h low riser heads - C8OF-D dist - 4100 carb  (Read 4650 times)
ntheogen
I'm looking for the following parts. Let me know what you may have that you would be willing to part with.
The last of the center oiler blocks, that have the 4 bolt motor mount casting. Decent condition only, I can't use anything windowed or majorly repaired. Looking for 3 of them.
C4ae-h low riser heads, bare, complete or in between.
C8OF-D 68 CJ distributor - date not important
4100 autolite carb - used on the 428 PI engines.
I have cash and/or parts to trade.
Thanks in advance.
Jack
540-664-for four one ate
Jacksfordparts geemail
jholmes217
Is the Police Interceptor Autolite venturi 1.08?
Jeff
4 speed, 3:50 traction lock
Olympia WA. area
ntheogen
I would have to defer to someone more knowledge on the subject. I'm definitely not a carb guru. I have a friend looking for one to complete his build.
might have the cylinder heads will check. They are complete. I know i have c3s not sure if they are H heads
ntheogen
Okay let me know when you get time to look, thanks.
babybolt
What about 427 Marine blocks?
ntheogen
No I'm looking for car blocks.
