Author Topic: Titanium valves on the street  (Read 4583 times)
winr1
« on: May 04, 2018, 11:59:08 PM »
Any run steel tipped Titanium valves on the street ??
Ricky.
Re: Titanium valves on the street
« Reply #1 on: May 05, 2018, 05:38:40 AM »
Yes sir.
winr1
« Reply #2 on: May 09, 2018, 12:30:01 AM »
Thanks Brent
May I ask if there is any guide material preference ??
Clearance an such to watch out far ??
Ricky.
« Reply #3 on: May 09, 2018, 04:58:56 AM »
What heads are they?
Most heads set up for titanium valves are going to have bronze guides and CuBe seats.  A cast iron seat will work as well on older factory heads.  Also will depend on how the valve stems are coated.
scott foxwell
« Reply #4 on: May 09, 2018, 07:11:22 AM »
No reason Ti valves can't be run on the street these days but I don't recommend hard tips. I prefer lash caps, especially on the street. Valve job, seat and valve finish, guide clearance, and as mentioned, seat and valve material or coatings are going to play a big part.
« Reply #5 on: May 09, 2018, 07:36:33 AM »
Probably not as critical on a lower spring pressure engine, but I agree, on big stuff, I'd rather have a lash cap than an insert.  I've seen the inserts break out.
scott foxwell
« Reply #6 on: May 09, 2018, 09:15:17 AM »
Careful agreeing with me...that might get you in trouble here... ::)
smileys!!! ^^^^
« Reply #7 on: May 09, 2018, 11:13:43 AM »
smileys!!! ^^^^
Just stay away from the bauxite!
 ;D
FWIW - I really like lash caps too....
scott foxwell
« Reply #8 on: May 09, 2018, 12:17:40 PM »
Quote
 ;D
I have a hangover... ??? :o
