Author Topic: Shelby alum. block oil path?  (Read 3536 times)
PaulProe
« on: April 28, 2018, 08:55:00 PM »
Has a graphic showing the oil path in a Shelby aluminum block ever been developed? Used search and I see various comments about the lack of one, but those date back to 2004/2005
I am trying to trace and understand the oil path. I have this graphic from an old article of a stock side-oiler but Shelby's are not the same
Paul
Re: Shelby alum. block oil path?
« Reply #1 on: May 01, 2018, 07:39:50 AM »
The Shelby block uses basically the same oiling system as a small block Ford.  It is a true priority main oiling system, as opposed to an FE topoiler or sideoiler.  If you find a diagram for a 289 or 302 oiling system you will get the basic idea.
PaulProe
« Reply #2 on: May 01, 2018, 08:38:34 PM »
Jay
Thanks for the reply. Today, I traced all the paths. I then recorded it both written and tried to do it graphically by modifying the image I originally posted.
Hope you and other experts will look this over and advise any corrections.
Paul
