Non-FE Discussion Forum
help
Topic: help (Read 5887 times)
whitea62.7t
Jr. Member
help
April 26, 2018, 05:00:03 AM »
I can't find .100 longer valves for a set of trick flow 11r heads for a 363 build
does anyone know how much custom SS valves cost and how long turn around is?
Thank you
Sean
Re: help
Reply #1 on:
April 26, 2018, 07:16:47 AM »
I can help if you give me a yell.
I'd need to know what kind of valves you're looking for (standard stainless, hollow stem, titanium, etc.) and the current lengths.
Instagram: brentlykinsmotorsports
YouTube: Lykins Motorsports
whitea62.7t
Jr. Member
Re: help
Reply #2 on:
April 26, 2018, 09:13:01 AM »
I need 5.3 length 8mm stainless valves for trockflow 11r 205 heads
2.08 and 1.6
Re: help
Reply #3 on:
April 26, 2018, 09:33:21 AM »
If you have suitable valves and are only looking for others due to length, lash caps will be a satisfactory solution.
whitea62.7t
Jr. Member
Re: help
Reply #4 on:
April 26, 2018, 09:39:54 AM »
I'm .100 short on installed height , .718 gross lift solid rollee
Re: help
Reply #5 on:
April 26, 2018, 09:54:25 AM »
Custom valves will be around $700-800 at first glance.
What about a +.100" retainer?
whitea62.7t
Jr. Member
Re: help
Reply #6 on:
April 26, 2018, 11:27:45 AM »
We need spring height for the lift , don't understand how a thicker retainer would help,I'm still learninh
Re: help
Reply #7 on:
April 26, 2018, 12:02:16 PM »
It's not a thicker retainer. It's a retainer that gives +.100" extra install height.
You can also use a +.050" valve lock. More than one way of getting there without buying valves.
whitea62.7t
Jr. Member
Re: help
Reply #8 on:
April 26, 2018, 12:59:25 PM »
Thank you very much for the info
help
