Author Topic: crankshaft pilot bushing  (Read 3748 times)
feadam
« on: April 23, 2018, 07:34:27 AM »
Got my engine together and opened my clutch kit box and there are three pilot bushings. The big bushing is the only one that fits crank, crank is aftermarket steel crank. Is this the right one to use, none of the three other bushings fit. The big one fits in crank closest to trans, it to big to go in smaller forward crank holes. This may sound like dumb question but haven't put a standard trans behind an FE since the eighties and never with aftermarket crank so want to make sure i get it right.
Faron
Re: crankshaft pilot bushing
« Reply #1 on: April 23, 2018, 08:25:16 AM »
Yep big hunk  of Brass
« Last Edit: April 23, 2018, 10:45:31 AM by Faron »
feadam
« Reply #2 on: April 23, 2018, 09:41:35 AM »
This one is tight going in is that common?
Faron
« Reply #3 on: April 23, 2018, 10:45:05 AM »
Aftermarket cranks can vary a few Thous , so Yes it may be a tad tight
feadam
« Reply #4 on: April 24, 2018, 04:28:25 PM »
Put flywheel on it was really tight also. I guess aftermarket cranks are machined tight
