Author Topic: Probe 445 pistons/pins and new 3G alternator  (Read 3840 times)
« on: April 15, 2018, 09:11:16 AM »
As you guys likely were following, my 445 had some bad machining done (no torque plate) and had some piston slap.  I haven't decided on a plan yet, but I am either going to get a 428 and stroke it to 462, or just fit a set of .040 pistons to by current block with proper machining this time.  Either way, I have a set of Probe Sportsman Racing pistons and pins left over.  Very little mileage and never run hard, looking for 350.00 plus the ride, these were a 550 dollar set of pistons when purchased.  They are 14785 +.030, 17.5 cc reverse dome, 2618 alloy.  A good set of stroker pistons for a 6.7 BBC rod and a 4.25 stroke for about 10:1 compression depending on deck height, head gasket and chamber size.
http://www.coasthigh.com/Ford-445FE-17-5cc-Reverse-Dome-SRS-Pistons-p/14785.htm
Also, I ended up with 2 3G alternator setups.  I have a Taurus 3G, which is the smaller case that is easy to use on an FE, along with a mega fuse holder, a mega fuse (100A), and the field/stator wiring harness to splice in, all new.  This is a new alternator, still in the box. Easily convert your car to a newer high output alternator.  Wiring diagrams all over the web. 80 bucks plus the ride for the new alternator, mega fuse, fuse holder/mounting bracket and harness)
« Last Edit: April 15, 2018, 11:07:08 AM by My427stang »
Re: Probe 445 pistons/pins and new 3G alternator
« Reply #1 on: April 15, 2018, 09:25:16 AM »
Pistons for a .030 over 390 block ?
« Reply #2 on: April 15, 2018, 09:37:12 AM »
Yes, 4.08 bore, for a 4.25 stroke and 6.7 rod
« Reply #3 on: April 15, 2018, 01:35:23 PM »
With a 100 amp fuse, am I correct in assuming that's the 95 amp alternator?
« Reply #4 on: April 15, 2018, 04:39:50 PM »
That is correct
Sale pending for both pistons and alternator, I will update ASAP
