Author Topic: Port matching TF Track Heat manifold to FE Power LLC adapter  (Read 4821 times)
AlanCasida
« on: April 13, 2018, 09:18:57 PM »
I have started port matching my Trick Flow Track Heat manifold to my adapter. I also opened up and smoothed the runner transition some...but not too smooth!
« Last Edit: April 13, 2018, 10:06:16 PM by AlanCasida »
Re: Port matching TF Track Heat manifold to FE Power LLC adapter
« Reply #1 on: April 14, 2018, 06:34:28 AM »
Nice!
Could use some tipside pics. Is the Trick Flow Track Heat intake from a 351C application? I wonder how big (width/height) the runners are nearer the plenum base.
L-o-n-g ago now here on Jay's site, before he started on the adaptor path, we had all discussed two other intake schemes: one was the two piece, bolt together single plane intakes (Chevy...but) that allow almost unlimited porting options, easy ones at that.
 http://www.jegs.com/p/Edelbrock/Edelbrock-Victor-Two-Piece-Design-Intake-Manifolds/1264061/10002/-1
The other was the then pretty new addition of plastic racing intakes for weight loss, cooling properties an more. Have to admit I have not heard much about these intakes in some years now but it's a viable idea for the adaptor.
« Last Edit: April 14, 2018, 06:42:09 AM by machoneman »
AlanCasida
« Reply #2 on: April 14, 2018, 07:58:22 AM »
Nice!
Yes it is a 351C intake.  I have seen some two piece Cleveland intakes on Ebay. They are for the Aussie 3V port configuration but I guess they can be modified to fit. They are Speedmaster units and pretty rough looking. This is what I started with:
https://www.trickflow.com/parts/tfs-51600111
