Author Topic: TomP - Check It Out!  (Read 4318 times)
« on: April 13, 2018, 10:35:38 AM »
Before....
A transmission appeared under all the grease:
Tommy-T
Re: TomP - Check It Out!
« Reply #1 on: April 13, 2018, 11:39:42 AM »
How dirty did YOU get during the transformation?
« Reply #2 on: April 13, 2018, 11:45:19 AM »
Nice! Got enough leftover oil from cleaning to fill her back up again with it!  ;)
« Reply #3 on: April 13, 2018, 11:49:12 AM »
$500 worth of Castrol SuperClean later!
« Reply #4 on: April 13, 2018, 01:29:52 PM »
haha! It actually wasn't that awful. Laid some trash bags down on the garage floor and took the scraper to it. My new favorite trick is WD-40 and scotch brite pads for cleaning things. The oil had turned into this semi-hardened sort of stuff that flaked off like chewing tobacco. No, I didn't try to chew any of it.
Lenz
« Reply #5 on: April 13, 2018, 02:13:44 PM »
Yep, we just talked about cleaning with kerosene, cheap and effective.  WD-40 gives the advantage of a mini pressure washer in the tight places.  "High garage tech" stuff everyone has too.  The tranny looks great!
Len Zielinski
'64 Galaxie 500 445 Toploader
'69 F100 300 stick
« Reply #6 on: April 13, 2018, 02:49:31 PM »
Amazes me how the oil plus dirt covering preserves the stuff underneath like the painted letters.
« Reply #7 on: April 13, 2018, 06:13:51 PM »
I was going to mention that also. Leaking engines are the best automotive preservative  ;D
« Reply #8 on: April 13, 2018, 06:20:02 PM »
As we say here, the only thing on a Opel
that s not rusted out is the front crossmember ;D
