Author Topic: 5.4L SOHC 24-valve SMFI Triton V8 engine  (Read 4897 times)
« on: April 02, 2018, 12:27:36 PM »
Are these engines any good at 200,000 miles ?
« Last Edit: April 02, 2018, 02:39:51 PM by fekbmax »
shady
Re: 5.4L SOHC 24-valve SMFI Triton V8 engine
« Reply #1 on: April 02, 2018, 12:53:16 PM »
I could have gave you an answer yesterday.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #2 on: April 02, 2018, 01:17:51 PM »
It's gas and uses 3 Valve per cylinder, they seem to be durable if maintained properly , common problems are exhaust manifold bolts busting off in the manifold causing exhaust leak , problems from lack of maintenance are timing chains (2 required ) guides and tensionors ( 2 required of each )
« Reply #3 on: April 02, 2018, 01:25:31 PM »
Yes to the above issues- and don't forget the problem with the spark plugs seizing in the aluminum heads and tearing out the threads.  That said, the 5.4L 3-valve can be quite durable if maintained properly.
No, it's not a diesel.  It most certainly does not have diesel low-end torque either, but it makes OK power in an F-150.
http://www.expertswrite.net/ford-5-4l-triton-3valve/common-problems.html
shady
« Reply #4 on: April 02, 2018, 02:18:13 PM »
Well, if it isn't an April fools joke, make sure it has new spark plugs. You don't want to have to change them.
« Reply #5 on: April 02, 2018, 02:20:55 PM »
The Factory plugs are the ones that break off , it actually breaks the lower casing that has the ground electrode from the spark plug due to carbon build up , threads are usually OK but it takes a tool to get the stuck piece out , aftermarket plugs don't seem to be a issue
« Reply #6 on: April 02, 2018, 02:41:56 PM »
Sorry , my bad on the diesel.  The fricking ad didn't go with the truck.
FishCakes428
5.4 oil leaks
« Reply #7 on: April 03, 2018, 09:10:16 PM »
I'm having a problem with a pretty bad oil leak now at 155,000 miles. Apparently Ford was/is aware of it. Burrs left on the deck surface after block machining interfering or compromising the gasket surrounding the oil ports. Or something like that. Oil leaking from head gasket passenger side rear and drivers side front. Pressurized oil ports from deck to head leaking out pretty bad. They have a revised head gasket that has the embossed areas slightly relocated. Gives the new gasket "fresh meat" deck surfaces to seal against. Original OEM gasket embossing can brinnel (?) into the deck surfaces. I have a 2001 5.4 with the PI heads. Limited years though. Course I have the bullseye year. And to boot, it's in an E-350! Engine under the dash.  Don't know what year you have. Search it out on the web and you'll get plenty of references to the problem.
Pop the dog house and take a look. Not hard to spot seeping or leaking on passenger side.
« Last Edit: April 03, 2018, 09:12:35 PM by FishCakes428 »
