Author Topic: Easiest internal regulator alternator swap for dual belt FE  (Read 9884 times)
« on: March 31, 2018, 06:11:58 PM »
I am having a tougher time finding voltage regulators that last for over a year or behave nicely, but I would like to keep my dual alternator belts and stock brackets
Does anyone have an easy swap for an FE that can take the dual groove pulley?
scott foxwell
Re: Easiest internal regulator alternator swap for dual belt FE
« Reply #1 on: March 31, 2018, 06:43:04 PM »
I bought a Tough Stuff 100A 1 wire from Summit. They say it's a Ford alternator but truth is, it;s a slightly different casting and if it's top mounted, it will not clear the passenger side cyl. head. I had to convert mine to low mount.
As far as the pulley, the dual pulley should fit the same as a single. No difference there.
« Reply #2 on: March 31, 2018, 06:52:07 PM »
Thanks Scott, would like to try to keep the top mount, but certainly an option over Chinese built regulators
« Reply #3 on: March 31, 2018, 07:43:06 PM »
The stock alternator for many late 80's Fords take the same pulley and there are models that use the same mounting pattern, holes opposite each other. I used an 89 Mustang 5.0L one (2G) on my Meteors 332 and it charged great. the bigger case later 3G ones, over 100 amps will fit if the bracket hangs the alternator below the head, maybe not if it mounts in front of the head. Dual belts is needed on those but a single V belt ran the 2G just fine.
The one on the right is what I ended up using, I tried the left one and shredded three belts before giving it up. Both were easy to wire and used a an inline Megafuse on a 6ga wire.
Whoa, sorry for the actual size picture,
« Last Edit: March 31, 2018, 07:45:28 PM by TomP »
« Reply #4 on: April 01, 2018, 02:18:31 PM »
Just a quick hint on pictures that come across that size, right click and hit "view image" and it'll show you a full screen shot.
stubbie
« Reply #5 on: April 01, 2018, 07:23:13 PM »
You could try here. A bit pricey but.
http://www.powerbastards.com/products.asp?cat=141915
KMcCullah
« Reply #6 on: April 01, 2018, 08:42:03 PM »
Have you ever tried the solid state Echlin regulator at NAPA? I'm not trying to change your mind on swapping alternators. Just curious if you ever tried one. I'm considering a 3G swap myself. Last summer the 45 year old point type regulator in my truck took a dump. It overcharged the shit out of my yellow top Optima. Way too aggressive for an AGM battery. The counter guy at NAPA talked me into trying the solid state regulator. It's probably made in China but it seems to take good care of the Optima.
Kevin McCullah
« Reply #7 on: April 01, 2018, 08:49:39 PM »
Certainly another option, but I think I am going to go 3G, gives me a reason to clean up the wiring too compared to the stock setup.  I am going to get a 7 inch 3G from a u-pull it yard and see how everything lines up and then make the call
KjcfeF100
« Reply #8 on: April 02, 2018, 09:26:11 AM »
I put a 3G on my 68 F100, and kept the dual V-belt pulley, and was able to use original mounting brackets.  IIRC I had to add a washer behind the pulley make it work correctly, but it all worked out well for me.  (Also, IIRC, I believe mine was off a '95 Mustang, I've got notes somewhere)
« Reply #9 on: April 02, 2018, 09:30:27 AM »
I use 3Gs on all my stuff now, but with the big 200 amp ones even the dual belts will tend to squeal a little on startup.  The ribbed belts take care of that problem.
« Reply #10 on: April 02, 2018, 09:33:02 AM »
Same here with 3g.
Anyone ever notice bulging AGMs?
« Reply #11 on: April 02, 2018, 10:31:25 AM »
I had the same experience as Scott when I did the Cougar. In September I changed over to a CVR water pump, electric fans, and a 200A powermaster alternator. It would not mount in the top position so I had to get an under-mount bracket. I ended up shaving down the lower bracket a bit so it quit rubbing on the alternator housing and would allow me to tighten it completely. It looks pretty clean in the lower position however. Cleaned up the wiring a ton too.
Tommy-T
« Reply #12 on: April 02, 2018, 11:45:11 AM »
Well...you can trash me if you want, but I've been using a Powermaster 8002 GM style 12si alternator on everything I've built for the last umpteen years.
100 amps, fit Ford brackets, and the stock Ford pulleys even fit. I was using a Ford dual belt pulley on my T-Bird.
I've never had one fail.
When the general has a Better Idea...I say run with it!
$125 at Summit or Jeggs.
« Reply #13 on: April 02, 2018, 01:01:22 PM »
I use 3G units from the scrap yard on both cars.  Use a bitty offbrand on the dragster.  FYI - To swap from rip to belt sheaves on a 3G you may need to source a thin shim to go behind the sheave because they typically rub the case.  Or machine the case a bit.  I run 6 rib crank and alternator on the race cars, little or no slippage.
« Reply #14 on: April 03, 2018, 06:28:44 AM »
I picked up a 3G and a Chevy internal regulator version.
Going to try the 3G first, and if I don't like it, I'll play with the GM.  Hope to be doing it this weekend, pics to come.  Thanks!
